Checking the configuration.yaml gives in the following error:
Invalid config for [sensor]: offset sensor.refresh_interval_waze should be format ‘HH:MM’, ‘HH:MM:SS’ or ‘HH:MM:SS.F’ for dictionary value @ data[‘scan_interval’]. Got None. (See /config/configuration.yaml, line 187).
result:
Invalid config for [sensor]: offset {{ states(‘sensor.refresh_interval_waze’) }} should be format ‘HH:MM’, ‘HH:MM:SS’ or ‘HH:MM:SS.F’ for dictionary value @ data[‘scan_interval’]. Got None. (See /config/configuration.yaml, line 188).
Perhaps you can use the service homeassistant.entity_update or whatever it’s called.
Have a very long update in the normal config of Waze sensor and use an automation to trigger on the input number, perhaps using a timer?
Then action update the entity.
