Waze_travel_time any way to edit an existing integration?
The waze_travel_time integration doesn’t appear to offer any way to edit origin or destination once the integration is created.
I have 3 autocreated travel time entities after an upgrade that I can’t change and can’t edit. The only way to change them is to delete the whole integration. This seems needlessly user unfriendy.
Am I missing something? Is there a way to edit an existing integration (where edit means change the source or dest.)
The documentation shows an example where one uses an input select to create a variable sensor. I recommend that.
Home Assistant is open source and of course one can edit any component, either by contributing to the development or creating your own local custom version of it. :grin:
