Since three days ago my Waze entities have not been updating, and looking at the logs I see this error (occurrences are low as I restarted HA to try and resolve it):
Logger: homeassistant
Source: components/waze_travel_time/sensor.py:320
First occurred: 16:16:29 (3 occurrences)
Last logged: 16:16:29
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/waze_travel_time/sensor.py", line 238, in first_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/waze_travel_time/sensor.py", line 264, in update
self._waze_data.update()
File "/usr/src/homeassistant/homeassistant/components/waze_travel_time/sensor.py", line 320, in update
routes = params.calc_all_routes_info(real_time=realtime)
File "/usr/local/lib/python3.9/site-packages/WazeRouteCalculator/WazeRouteCalculator.py", line 203, in calc_all_routes_info
results = {route['routeName']: self._add_up_route(route['results'], real_time=real_time, stop_at_bounds=stop_at_bounds) for route in routes}
File "/usr/local/lib/python3.9/site-packages/WazeRouteCalculator/WazeRouteCalculator.py", line 203, in <dictcomp>
TypeError: list indices must be integers or slices, not str
I added the integration via the UI (not sure you can do it in yaml anymore). It was working just fine until a few days ago. Using the EU region.
Can anyone help me with this? It is quite an important integration for me.
Thanks!
