Weather Flex Card - The Most Flexible and Feature Rich Forecast card available
Weather Flex Card
The Most Flexible and Feature Rich Forecast card available for Home Assistant.
A fully-customizable weather card that lets you build exactly the weather display you want — current conditions, hourly/daily forecasts, a sky-brightness gradient bar, a sunrise/sunset arc, and a digital clock — each an independent, reorderable section with its own styling. Every section can pull from multiple weather entities and your own sensors.
… all in a super easy to use Visual Editor — no YAML required unless you prefer it.
Special thank you to Tero Roininen’s ha-weather-forecast-card which is a card I loved and was my inspiration. Most of the code is original to my card but a few visual elements you will recognize came from his card.
:sparkles: Features
  • Sectioned, reorderable layout – The card is built from independent sections — Current Weather Header, Current Weather Metrics, Hourly Forecast, Daily Forecast, Sky Bar, Sun Position, and Clock & Date. Drag to reorder, show/hide any section, and style each one on its own.
  • Multiple weather sources – Set a Primary weather entity, a Fallback entity, and per-metric Custom overrides (any entity — a weather integration or your own sensor). Resolution runs Custom → Primary → Fallback → blank, so you can mix the best data source for each value. Forecasts merge across multiple entities.
  • Card Appearance – Full card-wrapper styling to match any dashboard: border (per-side toggles + per-corner rounding), background color, glow, and a separate drop-shadow (color / X / Y / blur / spread / opacity). Custom weather-condition icon path and moon-phase shading included.
  • Current Weather Header – Independent size controls for the condition icon, condition text, and temperature; a configurable sub-header metric (defaults to today’s high/low), a custom friendly name, and a header metrics row drawn from built-in metrics and/or any entity.
  • Current Weather Metrics – Display any set of weather metrics as a Grid/Wrap list or as Chips. Chips are fully styleable (text size, icon size, icon color, pill or custom corner radius, columns, show name/icon, hide-when-empty). Global value styling with per-value “Custom” overrides.
  • Hourly & Daily Forecasts – Each type independently controls its display mode (Simple or Chart), extra attribute, chart attribute, and number of slots to show. Load only the forecast types you display to reduce websocket load on constrained devices.
  • Sky Bar (brightness & color gradient) – A time-axis gradient showing day/night brightness and cloud cover. Configure the timeframe (fixed hours / full day / match the Sun Position arc), bar size and gradient colors, current-time marker, sunrise/sunset markers, and time labels + tick marks with adjustable “show a label/tick every N hours” spacing.
    • Forecast Weather Metrics on the bar – Overlay temps, condition icons, and extra attributes (wind, precipitation probability, UV, etc.) directly on the bar. Full ordering and per-side placement (above / on / below), with per-metric overrides for color, size, legibility, and “Show every” sampling — every forecast hour, on tick marks, between tick marks, or every N hours.
  • Sun Position arc – A sunrise → solar-noon → sunset arc with a live sun marker, configurable window, tick marks, and sunrise/sunset time labels and icons.
  • Clock & Date – An optional digital clock and date rendered in the header row. Independent placement, 12/24-hour format, seconds, popular date-format presets, per-element fonts/colors, and separate text-legibility (shadow/outline/auto) options for the time and the date.
  • Per-section styling – Every section shares a consistent Section Styles panel: flush-to-edge/top/bottom, section dividers (above/below with thickness, length, style, color), and a semi-transparent section background — all with independent values per section.
  • Full visual editor – Everything is configurable through the visual editor, organized into collapsible panels and sub-panels with per-section Reset buttons, modern sliders/dropdowns, and a read-only YAML view. Optional auto-collapse keeps the editor tidy.
:rocket: Installation
  1. Create the folder \config\www\community\weather-flex-card
  2. Download weather-flex-card.js and place it in that folder.
  3. Add as a Dashboard Resource:
    • Go to Settings > Dashboards > three-dot menu > Add Resource
    • Enter /local/community/weather-flex-card/weather-flex-card.js and select “JavaScript Module”
    • Click “Add”
  4. Clear your browser cache and refresh.
:camera_with_flash: Screenshots
Example showing just a fraction of the available options…
Impressive work :+1:
Are you planning on making this available via HACS?
I’m avoiding fully manual installations as I can’t keep track of updates.
Very nice work and the customization ability is really done well. Any chance you have thought of adding the ability to include radar maps as one of the data points. An example would be the one available at windy.com .
I wish publishing on HACS was quick and easy, it is neither. I’ve had a card waiting for over 3 months.
I have more cards I’m posting, updating and a few I want to build still; so better to spend the time making cards than trying to work through the flaming hoops to get them on HACS.
Potentially. I think you mean ‘radar’ as an animated image? I dont know what you mean by data point in this case?
Yes, you are corrected, the ability to include a radar source as an animated section.
