Weather forecast not shoow days show only next few hours
Hey,
But the card that comes up shows odd forecasts. It’s for the next few hours instead of few days. Where is the configuration to change this? show to all days.
  - platform: wunderground
    api_key: 20eff3b6ee3
    mode: daily
    monitored_conditions:
      - weather
      - temp_c
      - feelslike_c
      - wind_mph
      - relative_humidity
      - pressure_mb
You have a weather underground sensor defined and a dark sky weather platform defined. Your frontend card is using the dark sky weather platform. Note that there is no weather platform for weather underground. Also, if this is your api_key consider asking a mod for help cleaning your post.
This is not my Api :slight_smile:
so what you offer me in order to resolve it?
Change your dark sky weather config to use daily, but it won’t be the weather from weather underground. If you are using the sensor from weather underground, there is no default ui card you can use, since it isn’t a weather platform. There are some community built cards you can search for though.
Sorry im still not get how to resolve this issue,
i chnage my config to
  - type: weather-forecast
    entity: weather.home
    mode: daily
but still i got same day only .
Don’t put the mode in the ui config, but in the configuration.yaml under your darksky weather platform. I’m surprised there is no error with the mode in the ui config.
now i just habe on my configuration.yaml
    api_key: 20effb6ee3
    mode: daily
      - weather
      - temp_c
      - feelslike_c
      - wind_mph
      - relative_humidity
      - pressure_mb
But still show the same.
You placed it in the weatherunderground sensor platform, see above for what you need to do.
