I have been using the following template sensor for almost one year, now it is returning a value of “Forecast” instead of the numerical forecast temperature. What changed with Home Assistant?
- trigger:
- platform: state
entity_id: weather.home
- platform: homeassistant
event: start
- action: weather.get_forecasts
type: daily
response_variable: daily
- name: Today's Forecast Temperature
unique_id: temperature_forecast_today
state: "Forecast"
attributes:
temperature: "{{ daily['weather.home'].forecast[0].temperature }}"
Nothing changed in Home Assistant…
You have literally set your state to “Forecast”:
If you want the template to supply the value for state, then the template needs to be where “Forecast” is.
When I do this
state: "{{ daily['weather.home'].forecast[0].temperature }}"
unit_of_measurement: "°F"
I get the following error:
Error adding entity sensor.today_s_forecast_temperature for domain sensor with platform template
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 640, in state
numerical_value = float(value) # type:ignore[arg-type]
ValueError: could not convert string to float: 'None'
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 609, in _async_add_entities
await coro
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 928, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1384, in add_to_platform_finish
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1023, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1148, in _async_write_ha_state
self.__async_calculate_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1085, in __async_calculate_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1029, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 642, in state
raise ValueError(
...<5 lines>...
) from err
ValueError: Sensor sensor.today_s_forecast_temperature has device class 'None', state class 'None' unit '°F' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: 'None' (<class 'str'>)
Getting closer…
When I remove unit_of_measurement: "°F"
it loads without an error, but the value returned is “None”
- trigger:
- platform: state
event: start
type: daily
Sensors with unit_of_measurement
defined require that the state be a numerical value.
If you want a unit you need to add an availability
to avoid issues at startup when the weather
entity hasn’t fully loaded. It also wouldn’t hurt to reject certain state changes of weather.home
- trigger:
- platform: state
not_to:
- unknown
- unavailable
event: start
type: daily
device_class: temperature
availability: "{{ has_value('weather.home') }}"
