Weather.home_hourly is missing?
What i cant understant? I try to make hours forecast card but weather.home_hourly isint work at all?
“Entity not available”
It is probably defined, but disabled by the integration, because the underlying service does not support it. What weather integration do you use?
Hi, thanks for the answer.
I use oob weather card… met no
I use met.no to and weather.home_hourly is a disabled entity. “Disabled by integration.”
Just figured out, that you can however enable that entity and get hourly reports.
Thanks, i found it. I feeel so stupid .
