Weather RGB light automation - Is there a better way to implement this?
I’ve got the Aqara gateway that’s plugged in outside my bedroom. I’d like to light this up blue if it’s going to rain and red if it’s going to be hot. For weekdays, it makes sense for it to be 5:30-7:30, however, during weekends, it would need to be delayed by a few hours.
Is there a cleaner way to do both cases in one automation? What about turning it off after a few hours? I guess that in the worst case scenario I have 6 separate automations.
- alias: Aqara Rain Light ON WEEKDAY
    platform: time
    at: '05:30:00'
  condition:
    - condition: and
      conditions:
      - condition: time
        weekday:
        - mon
        - tue
        - wed
        - thu
        - fri
      - condition: state
        entity_id: group.all_devices
        state: 'home'
      - condition: template
        value_template: '{{ states.sensor.dark_sky_precip_probability.state | float > 50 }}'
        value_template: '{{ states.sensor.dark_sky_precip_intensity.state | float > 0.001 }}'
    - service: light.turn_on
        entity_id: light.gateway_rgb
        brightness_pct: 25
        rgb_color: [0,63,255]
You could create a workday sensor:
then use a template trigger to tell you automation to trigger at 05:30 if the workday sensor is ‘on’ or at 07:30 (or whatever) if it’s ‘off’.
then in your action: section you could tell the light to turn on then put in a 2 hour delay then tell the light to turn off.
Indeed if you use the workday sensor, it should adjust to your local holidays.
