I created a custom weather card.
When I tap on the card, the weekly forecast opens.
Everything is running fine so far, the only problem is that between 00:00 and 03:00 I apparently don’t receive any data, and the card runs into an error, so that only the faulty code is visible.
Anyone have an idea what could be causing this?
Here is the excerpt from my `configuration.yaml:
- trigger:
- platform: time_pattern
hours: /1
- platform: homeassistant
event: start
- service: weather.get_forecasts
entity_id:
- weather.tomorrow_io_daily
type: hourly
response_variable: hourly
entity_id:
type: daily
response_variable: daily
- name: Wetter Vorhersage alles
unique_id: wetter_vorhersage_alles
state: "{{ now().isoformat() }}"
attributes:
now_condition: >
{% from 'weather_translate.jinja' import translate_condition %}
{{ translate_condition(hourly['weather.tomorrow_io_daily'].forecast[0].condition) }}
now_icon: >
{% set weather = hourly['weather.tomorrow_io_daily'].forecast[0].condition %}
{% if is_state('sun.sun', 'above_horizon') %}
{{ '/local/weather_icons/' + weather + '.svg' }}
{% else %}
{{ '/local/weather_icons/' + weather + '_night.svg' }}
{% endif %}
now_wind_direction: >
{% set direction = ['N','NNO','NO','ONO','O','OSO','SO','SSO','S','SSW','SW','WSW','W','WNW','NW','NNW','N'] %}
{% set degree = (hourly['weather.tomorrow_io_daily'].forecast[0].wind_bearing | float) %}
{{ direction[((degree+11.25)/22.5)|int] }}
now_wind_desc: >
{% from 'weather_wind.jinja' import get_wind_description %}
{{ get_wind_description(hourly['weather.tomorrow_io_daily'].forecast[0].wind_speed | float) }}
{% set sensor = (hourly['weather.tomorrow_io_daily'].forecast[0].wind_speed | float) %}
{% if sensor > 0 and sensor < 0.99 %}
Windstille
{% elif sensor > 1 and sensor < 6.99 %}
Leiser Zug
{% elif sensor > 7 and sensor < 11.99 %}
Leichte Brise
{% elif sensor > 12 and sensor < 19.99 %}
Schwacher Wind
{% elif sensor > 20 and sensor < 29.99 %}
Mäßiger Wind
{% elif sensor > 30 and sensor < 39.99 %}
Frischer Wind
{% elif sensor > 40 and sensor < 50.99 %}
Starker Wind
{% elif sensor > 51 and sensor < 62.99 %}
Streifer Wind
{% elif sensor > 63 and sensor < 75.99 %}
Stürmischer Wind
{% elif sensor > 76 and sensor < 87.99 %}
Sturm
{% elif sensor > 88 and sensor < 102.99 %}
Schwerer Sturm
{% elif sensor > 103 and sensor < 117.99 %}
Orkanartiger Sturm
{% else %}
Orkan
{% endif %}
now_temp: "{{ hourly['weather.tomorrow_io_daily'].forecast[0].temperature }}"
now_precipitation: "{{ hourly['weather.tomorrow_io_daily'].forecast[0].precipitation }}"
now_precipitation_probability: "{{ hourly['weather.tomorrow_io_daily'].forecast[0].precipitation_probability }}"
now_humidity: "{{ hourly['weather.tomorrow_io_daily'].forecast[0].humidity }}"
now_wind_speed: "{{ hourly['weather.tomorrow_io_daily'].forecast[0].wind_speed }}"
today_condition: >
{{ translate_condition(daily['weather.tomorrow_io_daily'].forecast[0].condition) }}
today_icon: >
{% set weather = daily['weather.tomorrow_io_daily'].forecast[0].condition %}
{% else %}
{% endif %}
today_wind_direction: >
{% set degree = (daily['weather.tomorrow_io_daily'].forecast[0].wind_bearing | float) %}
today_wind_desc: >
Windstille
Leiser Zug
Leichte Brise
Schwacher Wind
Mäßiger Wind
Frischer Wind
Starker Wind
Streifer Wind
Stürmischer Wind
Sturm
Schwerer Sturm
Orkanartiger Sturm
{% else %}
Orkan
{% endif %}
today_temp: "{{ daily['weather.tomorrow_io_daily'].forecast[0].temperature }}"
today_precipitation: "{{ daily['weather.tomorrow_io_daily'].forecast[0].precipitation }}"
today_precipitation_probability: "{{ daily['weather.tomorrow_io_daily'].forecast[0].precipitation_probability }}"
today_humidity: "{{ daily['weather.tomorrow_io_daily'].forecast[0].humidity }}"
today_wind_speed: "{{ daily['weather.tomorrow_io_daily'].forecast[0].wind_speed }}"
forc1_datetime: "{{ daily['weather.tomorrow_io_daily'].forecast[1].datetime }}"
forc1_condition: >
{{ translate_condition(daily['weather.tomorrow_io_daily'].forecast[1].condition) }}
forc1_icon: >
{% set weather = daily['weather.tomorrow_io_daily'].forecast[1].condition %}
forc1_temp: "{{ daily['weather.tomorrow_io_daily'].forecast[1].temperature }}"
forc1_precipitation: "{{ daily['weather.tomorrow_io_daily'].forecast[1].precipitation }}"
forc2_datetime: "{{ daily['weather.tomorrow_io_daily'].forecast[2].datetime }}"
forc2_condition: >
{{ translate_condition(daily['weather.tomorrow_io_daily'].forecast[2].condition) }}
forc2_icon: >
{% set weather = daily['weather.tomorrow_io_daily'].forecast[2].condition %}
forc2_temp: "{{ daily['weather.tomorrow_io_daily'].forecast[2].temperature }}"
forc2_precipitation: "{{ daily['weather.tomorrow_io_daily'].forecast[2].precipitation }}"
forc3_datetime: "{{ daily['weather.tomorrow_io_daily'].forecast[3].datetime }}"
forc3_condition: >
{{ translate_condition(daily['weather.tomorrow_io_daily'].forecast[3].condition) }}
forc3_icon: >
{% set weather = daily['weather.tomorrow_io_daily'].forecast[3].condition %}
forc3_temp: "{{ daily['weather.tomorrow_io_daily'].forecast[3].temperature }}"
forc3_precipitation: "{{ daily['weather.tomorrow_io_daily'].forecast[3].precipitation }}"
forc4_datetime: "{{ daily['weather.tomorrow_io_daily'].forecast[4].datetime }}"
forc4_condition: >
{{ translate_condition(daily['weather.tomorrow_io_daily'].forecast[4].condition) }}
forc4_icon: >
{% set weather = daily['weather.tomorrow_io_daily'].forecast[4].condition %}
forc4_temp: "{{ daily['weather.tomorrow_io_daily'].forecast[4].temperature }}"
forc4_precipitation: "{{ daily['weather.tomorrow_io_daily'].forecast[4].precipitation }}"
forc5_datetime: "{{ daily['weather.tomorrow_io_daily'].forecast[5].datetime }}"
forc5_condition: >
{{ translate_condition(daily['weather.tomorrow_io_daily'].forecast[5].condition) }}
forc5_icon: >
{% set weather = daily['weather.tomorrow_io_daily'].forecast[5].condition %}
forc5_temp: "{{ daily['weather.tomorrow_io_daily'].forecast[5].temperature }}"
forc5_precipitation: "{{ daily['weather.tomorrow_io_daily'].forecast[5].precipitation }}"
