I’m trying to use the WUnderground Componet, by adding the code found here to my configuration.yaml file, when I restart HASS it doesn’t load and when I check the config file at YAMLlint, I get “(): mapping values are not allowed in this context at line 53 column 12”.
This is the line referred to above “api_key: your_api_key” where I added my api key that I got from WeatherUnderground…
Any ideas?
