Hi All,
I always had the weather underground addon until it broke. Now I'm trying to fix it using: GitHub - cytech/Home-Assistant-wundergroundpws: Home Assistant custom component sensor for Weather Underground personal weather station users · GitHub
But I'm unclear how this works and I think it's because I'm a noob user. It says I have to use HACS to install it which I think I did. But when I follow the path in te menu through: settings, devices & services, add a new integration and select wunderground pws it tells me:
"This integration cannot be added from the UI
You can add this integration by adding it to your 'configuration.yaml'. See the documentation for more information."
I found this post which explains I need to use core Weather Underground addon but the manual doesn't mention it at all.
The steps in the installation in the addon github are:
- Open HACS within HomeAssistant
- Within HACS, select the 3-dot button (top right) and then Custom repositories from the menu
- In the dialog that appears, enter the following:
- Repository:
cytech/Home-Assistant-wundergroundpws - Category:
Integration
- Click Add
- Now in the Search tab of HACS, search for "wundergroundpws"
But what do I do after step 5???
The manual install is mentioning all kinds of configuration you can do (like set the API key which I had done before while it was still working).
My gut says I must be missing something.
It would be awesome if one of you can point me in the right direction.
Thanks in advance.
Kind regards
