Web UI unreachable after fresh installation
After install HASS web UI is unreachable.
I used this guides:
  1. https://www.home-assistant.io/docs/installation/centos/
  2. https://www.home-assistant.io/docs/installation/virtualenv/#step-4-set-up-the-virtualenv
    My configuration.yaml - is default, but commented introduction section.
$ sudo systemctl restart home-assistant@simyrik && sudo journalctl -f -u home-assistant@simyrik:
-- Logs begin at Ср 2018-08-01 22:53:10 +07. --
авг 02 00:15:45 24 hass[13167]: 2018-08-02 00:15:45 INFO (MainThread) [homeassistant.core] Starting Home Assistant
авг 02 00:15:45 24 hass[13167]: 2018-08-02 00:15:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
авг 02 00:15:45 24 hass[13167]: 2018-08-02 00:15:45 INFO (MainThread) [homeassistant.core] Timer:starting
авг 02 00:16:30 24 hass[13167]: 2018-08-02 00:16:30 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_dawn=2018-08-02T05:41:05+00:00, next_dusk=2018-08-01T18:31:37+00:00, next_midnight=2018-08-02T00:06:16+00:00, next_noon=2018-08-02T12:06:18+00:00, next_rising=2018-08-02T06:02:48+00:00, next_setting=2018-08-01T18:09:52+00:00, elevation=12.1, azimuth=288.12, friendly_name=Sun @ 2018-08-01T17:15:44.355599+00:00>, new_state=<state sun.sun=above_horizon; next_dawn=2018-08-02T05:41:05+00:00, next_dusk=2018-08-01T18:31:37+00:00, next_midnight=2018-08-02T00:06:16+00:00, next_noon=2018-08-02T12:06:18+00:00, next_rising=2018-08-02T06:02:48+00:00, next_setting=2018-08-01T18:09:52+00:00, elevation=11.92, azimuth=288.11, friendly_name=Sun @ 2018-08-01T17:15:44.355599+00:00>>
авг 02 00:16:46 24 systemd[1]: Stopping Home Assistant...
авг 02 00:16:46 24 hass[13167]: 2018-08-02 00:16:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_stop[L]>
авг 02 00:16:46 24 hass[13167]: 2018-08-02 00:16:46 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_close[L]>
авг 02 00:16:46 24 hass[13167]: Config directory: /home/simyrik/.homeassistant
авг 02 00:16:46 24 systemd[1]: Started Home Assistant.
авг 02 00:16:46 24 systemd[1]: Starting Home Assistant...
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=restart>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=check_config>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=homeassistant, service=reload_core_config>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=create>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=persistent_notification, service=dismiss>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up recorder
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=recorder, service=purge>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up http
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up api
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=websocket_api>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up system_log
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=system_log, service=clear>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=system_log, service=write>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=system_log>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up auth
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=auth>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up onboarding
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=onboarding>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up frontend
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.4 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.2 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up history
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up sun
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sun>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded sensor.yr from homeassistant.components.sensor.yr
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up sensor
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up map
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=map>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded tts.google from homeassistant.components.tts.google
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up group
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=group, service=reload>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=group, service=set>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=group, service=remove>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=group, service=set_visibility>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=group>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=None, new_state=<state sun.sun=above_horizon; next_dawn=2018-08-02T05:41:05+00:00, next_dusk=2018-08-01T18:31:37+00:00, next_midnight=2018-08-02T00:06:16+00:00, next_noon=2018-08-02T12:06:18+00:00, next_rising=2018-08-02T06:02:48+00:00, next_setting=2018-08-01T18:09:52+00:00, elevation=11.85, azimuth=288.11, friendly_name=Sun @ 2018-08-01T17:16:47.695927+00:00>>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up conversation
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=conversation>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up config
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up automation
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=trigger>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=reload>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=toggle>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=turn_on>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=turn_off>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=automation>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up logbook
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logbook, service=log>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logbook>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up script
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=script, service=reload>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=script, service=turn_on>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=script, service=turn_off>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=script, service=toggle>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=script>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded config.group from homeassistant.components.config.group
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.group>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded config.customize from homeassistant.components.config.customize
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.customize>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded config.hassbian from homeassistant.components.config.hassbian
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded config.entity_registry from homeassistant.components.config.entity_registry
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded config.automation from homeassistant.components.config.automation
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.automation>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded config.core from homeassistant.components.config.core
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.core>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded config.config_entries from homeassistant.components.config.config_entries
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.loader] Loaded config.script from homeassistant.components.config.script
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.script>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up discovery
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.entity_registry>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up updater
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yr
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.yr_symbol, old_state=None, new_state=<state sensor.yr_symbol=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=yr Symbol, entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png @ 2018-08-01T17:16:47.796024+00:00>>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up cloud
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=cloud>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setting up tts
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.config_entries>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.1 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=tts, service=google_say>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=tts, service=clear_cache>
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds.
авг 02 00:16:47 24 hass[13211]: 2018-08-02 00:16:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=tts>
авг 02 00:16:48 24 hass[13211]: 2018-08-02 00:16:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.yr_symbol, old_state=<state sensor.yr_symbol=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=yr Symbol, entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png @ 2018-08-01T17:16:47.796024+00:00>, new_state=<state sensor.yr_symbol=2; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=yr Symbol, entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=2;content_type=image/png @ 2018-08-01T17:16:48.456865+00:00>>
авг 02 00:16:48 24 hass[13211]: 2018-08-02 00:16:48 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.8 seconds.
авг 02 00:16:48 24 hass[13211]: 2018-08-02 00:16:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sensor>
авг 02 00:16:48 24 hass[13211]: 2018-08-02 00:16:48 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 1.38s
авг 02 00:16:48 24 hass[13211]: 2018-08-02 00:16:48 INFO (MainThread) [homeassistant.core] Starting Home Assistant core loop
авг 02 00:16:48 24 hass[13211]: 2018-08-02 00:16:48 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
авг 02 00:16:48 24 hass[13211]: 2018-08-02 00:16:48 INFO (MainThread) [homeassistant.core] Timer:starting
авг 02 00:17:30 24 hass[13211]: 2018-08-02 00:17:30 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_dawn=2018-08-02T05:41:05+00:00, next_dusk=2018-08-01T18:31:37+00:00, next_midnight=2018-08-02T00:06:16+00:00, next_noon=2018-08-02T12:06:18+00:00, next_rising=2018-08-02T06:02:48+00:00, next_setting=2018-08-01T18:09:52+00:00, elevation=11.85, azimuth=288.11, friendly_name=Sun @ 2018-08-01T17:16:47.695927+00:00>, new_state=<state sun.sun=above_horizon; next_dawn=2018-08-02T05:41:05+00:00, next_dusk=2018-08-01T18:31:37+00:00, next_midnight=2018-08-02T00:06:16+00:00, next_noon=2018-08-02T12:06:18+00:00, next_rising=2018-08-02T06:02:48+00:00, next_setting=2018-08-01T18:09:52+00:00, elevation=11.69, azimuth=288.09, friendly_name=Sun @ 2018-08-01T17:16:47.695927+00:00>>
$ netstat --tcp --listening --programs --numeric:
(Not all processes could be identified, non-owned process info
 will not be shown, you would have to be root to see it all.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:8123            0.0.0.0:*               LISTEN      13211/python3
tcp6       0      0 :::22                   :::*                    LISTEN      -
