An add-on that connects to the Weber Connect Smart Grilling Hub over Bluetooth and publishes probe sensors via MQTT discovery. Fully local - no Weber cloud or account.
Pairing from a built-in panel: tap Find My Hub, press the hub's button to confirm
Probe temperature/state sensors, battery for wireless probes, no YAML
Handoff mode so the Weber phone app can still connect when you want it
Good catch, thank you. Home Assistant has renamed Add-ons to Apps in newer versions, and my install wording was using the older label.
I’ve updated the README to say: Settings > Apps > Install app > Repositories. Older Home Assistant versions may still show Settings > Add-ons > Add-on Store.
