Webgui Fails to Load with Envisalink and 0.64
When I comment out my envisalink configurate HA loads fine otherwise the gui fails to load after the 0.64 install, prior version worked with no changes.
Here is service status with config uncommented.
* home-assistant.service - Home Assistant
   Loaded: loaded (/etc/systemd/system/home-assistant.service; enabled; vendor preset: enabled)
   Active: active (running) since Sat 2018-03-03 11:06:33 EST; 26s ago
 Main PID: 254 (hass)
   CGroup: /system.slice/home-assistant.service
       `-254 /usr/bin/python3 /usr/local/bin/hass
Mar 03 11:06:39 HomeAssistantUbuntu16d04 hass[254]: 2018-03-03 11:06:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state device_tracker.hdhr103305b2=not_home; source_type=None, friendly_name=HDHR-103305B2 @ 2018-03-03T11:06:39.320157-05:00>, new_state=<sta
Mar 03 11:06:39 HomeAssistantUbuntu16d04 hass[254]: 2018-03-03 11:06:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state device_tracker.aarons_iphone=not_home; source_type=None, friendly_name=Aaron's iPhone @ 2018-03-03T11:06:39.326028-05:00>, new_state=<s
Mar 03 11:06:39 HomeAssistantUbuntu16d04 hass[254]: 2018-03-03 11:06:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state device_tracker.sullivansmbp_2=not_home; source_type=None, friendly_name=Sullivans-MBP @ 2018-03-03T11:06:39.286468-05:00>, new_state=<s
Mar 03 11:06:39 HomeAssistantUbuntu16d04 hass[254]: 2018-03-03 11:06:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state device_tracker.ac1f6b66b4c5=not_home; source_type=None, friendly_name=ac1f6b66b4c5 @ 2018-03-03T11:06:39.308322-05:00>, new_state=<stat
Mar 03 11:06:39 HomeAssistantUbuntu16d04 hass[254]: 2018-03-03 11:06:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state device_tracker.homeassistantubuntu16d04=not_home; source_type=None, friendly_name=HomeAssistantUbuntu16d04 @ 2018-03-03T11:06:39.349036
Mar 03 11:06:39 HomeAssistantUbuntu16d04 hass[254]: 2018-03-03 11:06:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state device_tracker.hdhr10479646=not_home; source_type=None, friendly_name=HDHR-10479646 @ 2018-03-03T11:06:39.315788-05:00>, new_state=<sta
Mar 03 11:06:39 HomeAssistantUbuntu16d04 hass[254]: 2018-03-03 11:06:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state device_tracker.sensi=not_home; source_type=None, friendly_name=Sensi @ 2018-03-03T11:06:39.317273-05:00>, new_state=<state device_track
Mar 03 11:06:39 HomeAssistantUbuntu16d04 hass[254]: 2018-03-03 11:06:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state device_tracker.pve_eth0=not_home; source_type=None, friendly_name=PVE eth0 @ 2018-03-03T11:06:39.331824-05:00>, new_state=<state device
Mar 03 11:06:47 HomeAssistantUbuntu16d04 hass[254]: 2018-03-03 11:06:47 WARNING (MainThread) [homeassistant.setup] Setup of envisalink is taking over 10 seconds.
Mar 03 11:06:47 HomeAssistantUbuntu16d04 hass[254]: 2018-03-03 11:06:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: level=WARNING, message=Setup of envisalink is taking over 10 seconds., exception=, timestamp=1520093207.4130988, source=bootstrap.py>
* service.service
   Loaded: not-found (Reason: No such file or directory)
   Active: inactive (dead)
Here is the log with config uncommented.
2018-03-03 11:06:36 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=160 from 2018-03-03 15:57:17.067453)
2018-03-03 11:06:37 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
    result = coro.throw(exc)
  File "/usr/lib/python3.5/asyncio/base_events.py", line 695, in create_connection
    raise exceptions[0]
  File "/usr/lib/python3.5/asyncio/base_events.py", line 682, in create_connection
    yield from self.sock_connect(sock, address)
  File "/usr/lib/python3.5/asyncio/selector_events.py", line 402, in sock_connect
    return (yield from fut)
  File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
    raise self._exception
  File "/usr/lib/python3.5/asyncio/selector_events.py", line 432, in _sock_connect_cb
    raise OSError(err, 'Connect call failed %s' % (address,))
ConnectionResetError: [Errno 104] Connect call failed ('192.168.190.10', 4025)
Here is the configuration.
#home alarm
envisalink:
  host: 192.168.190.10
  panel_type: DSC
  user_name: user
  password: user
  code: '1234'
  port: 4025
  evl_version: 3
  keepalive_interval: 60
  zonedump_interval: 30
  panic_type: Police
Only 1 device at a time can be logged into the envisalink. Check to see that you don’t have a phone or tablet logged in through an app. The web frontend failing to load isn’t a surprise and doesn’t necessarily mean it’s a configuration issue. In my experience If you have an envisalink component in your config but HA isn’t connecting to it then it will stop HA from loading.
It’s always just after I post I figure these things out. Envisalink changed their password requirement for local access, meaning you have to change from default.
The problem comes when you restart HASS
Its only one instance connected but when restarting it seems that think its already connected and HASS does not start
I have to do a full Reboot for hass to start fine.
Any ideas ?
How do you fix this ?
My specific issue was that I could not load the Envisalink module because Envisalink changed their password requirements. If you have a similar issue you should see it in the log than you can comment it out of your config to see if that fixes anything.
If you have the same specific Envisalink issue than you need to set a password and store that in your HA config.
What can we do with this , I can’t even restart all the time fails because it thinks Envisalink is still connected to Home Assistant Maybe a configuration to change ? In Envisalink or HASS ?
Any feedback on this ? Are you having the same problem as I Do with Envisalink ?
Thanks in advance
You need to review your log file and check why it won’t start. If it is the Envisalink go into your config.yaml file and comment it out so HA won’t try to load it. If you are having the same issue as me you will need to create a pw for Envisalink access on your network before uncommenting the Envisalink module in your HA config file.
Hi @ams123 thanks for the reply
Thats what I did , I commented out envisalink and HASS restarts without a problem
But when I try to restart when envisalink is working it gets stuck trying to restart
I changed the password but still having the same problem.
Can you post the relevant output of log file.
Nothing to see on the log its just stops there trying to load HASS but can’t .
No errors at all until I fully reboot the computer and then it works fine.
