I have a webhook automation that’s receiving a base64 encoded image (snapshot: ....). I’m having a hard time figuring out how to convert that base64 to a normal image I can then use in lovelace.
What template or else can I use?
Thanks a lot
Thanks a lot
similar thing, just pdf but works the same: Please help with a shell script to save a file locally
there might be a ton of other options, you’ll see them in a bit posted by other users ![]()
