Hi, after a little help, not sure there I’m going wrong here. I have an IFTTT webhook applet that works if I’m using to turn in a entity such as a light. But getting it to run a script seems to do nothing. The script is fine, I can trigger it manually from hassio. Maybe my body text or service template format?
It’s really odd. I can trigger webhook events like turning off lights ect, but scripts are a no go. I can activate my script fine from the dashboard. Maybe the issue is the IFTTT automation yaml template. Maybe it’s a different syntax for actioning scripts?
not sure, you’d need to watch your home-assistant.log file with debug set so you can see incoming events. Also, use the reply attached to peoples posts and they will get a notification that you replied, otherwise they’ll never know you replied. Pretty much the reason why I didn’t notice your post til today.
