I am new to HA. please be kind…
My HA system is connected to my Home router via cable with static IP: 192.168.2.40 and to my Van (when it’s present) via wifi to vans Teltonika router with static IP: 192.168.10.108, so on two different subnet’s.
I have a Victron system setup in the van with a Cerbo GX, home page is 192.168.10.10
I have setup a HA Webpage dashboard with URL pointing to my van cerbo dashboard but it will not connect (time out error), but when the PC I am using to view home assistant connects to my van (wifi) everything works. This suggests that HA is using the network from my PC and not it’s own network connections, is this correct? is there something I am doing wrong?
So all works ok, but when I turn off my PC, home assistant can no longer show the van cerbo webpage? (everything is addressed by HTTP, no HTTPS)
