Webrtc-camera stream refresh issue (maybe from a recent update)
Hi!
In the past, I was using custom:webrtc-camera in combination with custom:button-card, in order to have a special manual button to refresh the camera stream and it was working perfectly, but from the last updates (dunno which one), it is not working anymore… This is the card:
type: custom:button-card
custom_fields:
    card:
      type: custom:webrtc-camera
      url: |
          return "rtsp://admin:[email protected]:554/h264Preview_01_sub#" + states['number.dummy_random_door_camera'].state;
      muted: true
      mode: mse
      media: video,audio
      ui: true
  click:
    card:
      icon: mdi:refresh
      tap_action:
        action: call-service
        service: homeassistant.update_entity
        service_data:
          entity_id: number.dummy_random_door_camera
styles:
  grid:
    - grid-template-areas: "'data' 'click'"
    - grid-template-columns: 1fr
I have removed the extra styles to have a smaller code for this post.
The “click” button was acting as randomizing the number value state of number.dummy_random_door_camera and the stream was refreshing…
Anyone knows an alternative to this or a solution?
Thanks!
I’m using just webrtc cards also and mine run for a few secounds and start spiining also. It started after the last update.
Hello PickOne
Did you ever find a solution to this ? I have the same problem.
Michael J
Hi! Yes, use force_recreate: true
Hello PickOne
Thanks, I’ll give it a try. I’m trying to build an automation that refreshes the camera entity every N’th minutes, as it constantsly looses the stream somewhere down the line.
Michael J
for cameras with losing stream issue, I don’t use the direct stream, you can use frigate or motioneye, then use the stream from addon, it will keep it good “auto-refreshing” inside the addon
Thanks s for the tip PickOne - appreciated !
Michael J
