Websocket Connection from Hass.io Addon Won't Authenticate
I’m trying to connect a websocket client to Home Assistant via a Hass.io addon.
This means I have the HASSIO_TOKEN environment variable with a valid token.
I then pass that on to my website, where I create the connection in Javascript.
If I use a long-lived access token, it works great.
But if I run it in a Hass.io addon container (where we aren’t supposed to need LLATs!), it doesn’t work.
Any ideas?
