Yes I can.
I can access the Home Assistant VM via the ESXI console.
I can also access any/all of the other VM’s that are running on that server.
There are currently 8 VM’s running, all are working fine except Home Assistant
What OS/browser do you use? Isn’t it Safari in macOS Tahoe, by chance?
If so try to access your HA either by home http://assistant.local:8123 (do not use IP), or, even better, if you have reverse proxy configured in your network use public URL.
I have just deployed a brand new instance without changing any settings and it’s picked up an IP address automatically so this is DEFINITELY something wrong with the original instance.
I really really don’t want to have to go through the whole setup again so I would REALLY like to get the original working.
ha net inf
In your console, also be aware that people can’t just keep on guessing
You have to provide structured troubleshooting facts (visible facts, not just your thought or similar)
PS: In Cli you can also find the various log-files
Read the CLI ( i.e , -h )after each commands gives you more info
After above net inf, also check your Router, as a Router is in fact You Home Primary IP Management Device
