Weekday vs Weekend Automation Config
With the current versions on Home Assistant, I would hope there is a less complex way to have an automation config that has an action to turn on a light at one time on a weekday and another time on a weekend. But it still seems overly complicated. This is what I’ve come up with, can anyone let me know if there is a simpler solution to handle this?
alias: Basement Light On
description: ""
  - platform: time
    at: "06:00:00"
    alias: Weekday Trigger
  - platform: time
    at: "09:00:00"
    alias: Weekend Trigger
condition: []
  - if:
      - condition: trigger
      - condition: state
        entity_id: binary_sensor.workday_sensor
        state: "on"
    then:
      - service: light.turn_on
        data: {}
          entity_id: light.basement
    alias: Weekday action
  - if:
      - condition: state
        state: "off"
    then:
        data: {}
    alias: Weekend action
mode: single
How are you defining “simpler”?
You can create a template sensor and trigger off that.
template:
- sensor:
  - name: Basement Light Time
    device_class: timestamp
    state: >
      {% set weekday = today_at("06:00") %}
      {% set weekend = today_at("09:00") %}
      {{ iif(is_state('binary_sensor.workday_sensor', 'on'), weekday, weekend) }}
And then your automation
description: ""
  - platform: time
    at: sensor.basement_light_time
Set up a Schedule helper via the UI. Then:
alias: Basement Light manager
  - platform: state
    entity_id: schedule.basement_light
  - service: light.turn_{{ trigger.to_state.state }}
This also turns it off based on your schedule — if that’s not time-based, how are you switching it off?
Alternatively, yet another way to do exactly what you’ve asked for:
  - platform: time
    at: "06:00:00"
  - platform: time
    at: "09:00:00"
condition:
  - "{{ is_state('binary_sensor.workday_sensor', trigger.id.split('_')[1]) }}"
Honestly, the way you have it seems to be pretty ‘simple’. You could also just have two different automations - and, while simpler, does create an extra automation.
Always multiple ways to do things in HA - really comes down to finding a ‘relatively standardized’ process (in your head anyways) and sticking w/ that.
Thanks everyone. I was trying to avoid referencing the same action twice, and these are some great ideas to explore.
