Weird behavior after updates
This morning I just updated and low and behold an erratic reading from a long held device stops zeroing out. Which only occurred since the previous core update.
I changed batteries, swapped devices and nothing. This mornings update it’s back stable again, fully functional, why? There’s nothing in release notes that’s relevant you’re focusing on voice again.
So what did the update redo after the previous one destabilised the Hygrometer - a device that’s been operational for years?
A week working out a patch, trying filters and buying a replacement device and it’s back stable and operational.
Hi Dave, what did you update?
Your post is not very clear about your real issue.
The only update available was the HAOS Core two in very quick succession so I’m guessing they caused it probably playing with device timeouts and tolerances and then reset it back to the previous value. The sensor is acting fine again after the quick reversal of whatever they did.
Good you it got solved!
Please take the time to mark the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to this).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
