After lates upgrade I notices some strange error in the log:
peError: expected bytes, NoneType found
Exception ignored in: 'libopenzwave.str_to_cppstr'
TypeError: expected bytes, NoneType found
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 4 100 4 0 0 707 0 --:--:-- --:--:-- --:--:-- 800
100 4 100 4 0 0 839 0 --:--:-- --:--:-- --:--:-- 1000
Looks like hass is trying to download something again and again…
It is visible in docker logs from the container…But not in the home-assistant.log…
After container restart I have:
2018-11-11 01:04:57 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2018-11-11 01:04:57 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
2018-11-11 01:04:57 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2018-11-11 01:04:57 INFO (MainThread) [homeassistant.setup] Setting up recorder
2018-11-11 01:04:57 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
2018-11-11 01:04:57 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
2018-11-11 01:04:57 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2018-11-11 01:04:58 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
2018-11-11 01:04:58 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2018-11-11 01:04:58 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2018-11-11 01:04:58 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2018-11-11 01:04:59 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2018-11-11 01:04:59 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger
2018-11-11 01:04:59 INFO (MainThread) [homeassistant.setup] Setting up logger
100 4 100 4 0 0 272 0 --:--:-- --:--:-- --:--:-- 285
2018-11-11 01:05:07 ERROR (MainThread) [homeassistant.components.hue] Error connecting to the Hue bridge at 10.0.0.119
2018-11-11 01:05:08 ERROR (MainThread) [homeassistant.components.hue] Error connecting to the Hue bridge at 10.0.0.119. Retrying in 2 seconds
Config directory: /config
100 4 100 4 0 0 269 0 --:--:-- --:--:-- --:--:-- 285
And than non stop the weird stuff.
In home-assistant.log the is only
