When I compile my project, it errors out and references template sensor. If i comment out the temperature rise template sensor, it compiles fine. I can’t see the error and am hoping someone can point me in the right direction.
# Supply temp/pressure
- platform: bmp280_i2c
i2c_id: bus_supply
# address: 0x77
# temperature:
# accuracy_decimals: 2
# id: supply_bmp_temp
# name: "Supply - BMP Temperature"
pressure:
name: "Supply - Pressure"
update_interval: 10s
- platform: aht10
i2c_id: bus_supply
# address: 0x38
temperature:
name: "Supply - Temperature"
humidity:
name: "Supply - Humidity"
# Return temp/pressure
i2c_id: bus_return
# address: 0x77
# temperature:
# id: return_bmp_temp
# name: "Return - BMP Temperature"
pressure:
name: "Return - Pressure"
- platform: aht10
i2c_id: bus_return
# address: 0x38
temperature:
name: "Return - Temperature"
humidity:
name: "Return - Humidity"
# Temperature Rise
unit_of_measurement: "°C"
lambda: |-
if (isnan(id(supply_temp).state) || isnan(id(return_temp).state)) {
return NAN;
} else {
return id(supply_temp).state - id(return_temp).state;
Here is the compilation error:
Compiling .pioenvs/esp-furnace/src/main.cpp.o
In file included from src/esphome/components/esp32_rmt_led_strip/led_strip.h:12,
from src/esphome.h:27,
from src/main.cpp:3:
/data/cache/platformio/packages/framework-espidf/components/driver/deprecated/driver/rmt.h:18:2: warning: #warning "The legacy RMT driver is deprecated, please use driver/rmt_tx.h and/or driver/rmt_rx.h" [-Wcpp]
18 | #warning "The legacy RMT driver is deprecated, please use driver/rmt_tx.h and/or driver/rmt_rx.h"
Linking .pioenvs/esp-furnace/firmware.elf
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/esp-furnace/src/main.cpp.o:(.literal._Z5setupv+0x3dc): undefined reference to `_ZTVN7esphome9template_14TemplateSensorE'
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/esp-furnace/src/main.cpp.o:(.literal._Z5setupv+0x3e0): undefined reference to `_ZTVN7esphome9template_14TemplateSensorE'
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/esp-furnace/src/main.cpp.o:(.literal._Z5setupv+0x4a4): undefined reference to `_ZN7esphome9template_14TemplateSensor12set_templateEOSt8functionIFNS_8optionalIfEEvEE'
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/esp-furnace/src/main.cpp.o: in function `_ZN7esphome5aht1014AHT10Component22set_temperature_sensorEPNS_6sensor6SensorE':
/data/build/esp-furnace/src/esphome/components/aht10/aht10.h:22: undefined reference to `_ZN7esphome9template_14TemplateSensor12set_templateEOSt8functionIFNS_8optionalIfEEvEE'
collect2: error: ld returned 1 exit status
*** [.pioenvs/esp-furnace/firmware.elf] Error 1
========================= [FAILED] Took 18.91 seconds =========================
