I was looking thru my logs on HA and found this entry:
2023-02-26 10:12:24.851 ERROR (Thread-6) [pychromecast.socket_client] [master shield(192.168.0.111):8009] Failed to connect to service ServiceInfo(type=‘mdns’, data=‘SHIELD-Android-TV-c2bc3560408db085ab0b1df5e0294da4._googlecast._tcp.local.’), retrying in 5.0s
So this is basically the master bedroom Shield TV but the IP isn’t 192.168.0.111. It’s a static IP ending in 57. I had previously deleted all my entries for the Shields and created them again without having that separate docker image setup but still seeing this. Any ideas where it’s coming from within HA?
Note to try and reset to baseline deleted the integration and added it back again. Any ideas how bad this is in general to navigate?
