Weird Problem - Home Assistant won't start, log and check from CLI return errors
Started having a problem today after trying to integrate an AWS InfluxDB as a sensor. After adding the lines to the config yaml, rebooting it didn’t work. I reverted the config and it still didn’t work. I went into the CLI and found some weird responses. I tried taking out everything from my config and am left with just the barebones, but it still won’t start home assistant. Feels like something went corrupt in a file onboard. How can I fix this?
hassio ha logs
Error decoding json invalid character 'T' looking for beginning of value: Traceback (most recent call last):
  File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "/usr/lib/python3.6/site-packages/homeassistant/__main__.py", line 374, in <module>
    sys.exit(main())
  File "/usr/lib/python3.6/site-packages/homeassistant/__main__.py", line 366, in main
    exit_code = setup_and_run_hass(config_dir, args)
  File "/usr/lib/python3.6/site-packages/homeassistant/__main__.py", line 245, in setup_and_run_hass
    from homeassistant import bootstrap
  File "/usr/lib/python3.6/site-packages/homeassistant/bootstrap.py", line 18, in <module>
    from homeassistant.setup import async_setup_component
  File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 13, in <module>
    import homeassistant.util.package as pkg_util
  File "/usr/lib/python3.6/site-packages/homeassistant/util/package.py", line 10, in <module>
    from pip.locations import running_under_virtualenv
  File "/usr/lib/python3.6/site-packages/pip/__init__.py", line 26, in <module>
    from pip.utils import get_installed_distributions, get_prog
  File "/usr/lib/python3.6/site-packages/pip/utils/__init__.py", line 23, in <module>
    from pip.locations import (
  File "/usr/lib/python3.6/site-packages/pip/locations.py", line 10, in <module>
    from distutils.command.install import install, SCHEME_KEYS  # noqa
  File "/usr/lib/python3.6/distutils/command/install.py", line 8, in <module>
    from distutils import log
ImportError: cannot import name 'log'
hassio ha check
        "result": "error",
        "message": "starting version 3.2.4\nTraceback (most recent call last):\n  File \"/usr/lib/python3.6/runpy.py\", line 193, in _run_module_as_main\n    \"__main__\", mod_spec)\n  File \"/usr/lib/python3.6/runpy.py\", line 85, in _run_code\n    exec(code, run_globals)\n  File \"/usr/lib/python3.6/site-packages/homeassistant/__main__.py\", line 374, in <module>\n    sys.exit(main())\n  File \"/usr/lib/python3.6/site-packages/homeassistant/__main__.py\", line 352, in main\n    from homeassistant import scripts\n  File \"/usr/lib/python3.6/site-packages/homeassistant/scripts/__init__.py\", line 10, in <module>\n    from homeassistant.bootstrap import mount_local_lib_path\n  File \"/usr/lib/python3.6/site-packages/homeassistant/bootstrap.py\", line 18, in <module>\n    from homeassistant.setup import async_setup_component\n  File \"/usr/lib/python3.6/site-packages/homeassistant/setup.py\", line 13, in <module>\n    import homeassistant.util.package as pkg_util\n  File \"/usr/lib/python3.6/site-packages/homeassistant/util/package.py\", line 10, in <module>\n    from pip.locations import running_under_virtualenv\n  File \"/usr/lib/python3.6/site-packages/pip/__init__.py\", line 26, in <module>\n    from pip.utils import get_installed_distributions, get_prog\n  File \"/usr/lib/python3.6/site-packages/pip/utils/__init__.py\", line 23, in <module>\n    from pip.locations import (\n  File \"/usr/lib/python3.6/site-packages/pip/locations.py\", line 10, in <module>\n    from distutils.command.install import install, SCHEME_KEYS  # noqa\n  File \"/usr/lib/python3.6/distutils/command/install.py\", line 8, in <module>\n    from distutils import log\nImportError: cannot import name 'log'\n"
hassio ha info
    "result": "ok",
    "data": {
        "version": "0.62.0",
        "last_version": "0.62.0",
        "image": "homeassistant/raspberrypi3-homeassistant",
        "custom": false,
        "boot": true,
        "port": 8123,
        "ssl": false,
        "watchdog": true
hassio s logs
Error decoding json invalid character '\x1b' looking for beginning of value: 18-01-29 16:02:26 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:02:26 INFO (SyncWorker_5) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:02:29 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:02:41 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:02:41 INFO (SyncWorker_10) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:02:44 INFO (SyncWorker_10) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:02:57 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:02:57 INFO (SyncWorker_2) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:02:59 INFO (SyncWorker_2) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:03:07 INFO (SyncWorker_12) [hassio.docker] Run command 'python3 -m homeassistant -c /config --script check_config' on homeassistant/raspberrypi3-homeassistant
18-01-29 16:03:26 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:03:26 INFO (SyncWorker_14) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:03:29 INFO (SyncWorker_14) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:03:42 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:03:42 INFO (SyncWorker_0) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:03:44 INFO (SyncWorker_0) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:03:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:03:56 INFO (SyncWorker_17) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:03:59 INFO (SyncWorker_17) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:04:12 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:04:12 INFO (SyncWorker_5) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:04:14 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:04:26 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:04:27 INFO (SyncWorker_10) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:04:29 INFO (SyncWorker_10) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:04:42 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:04:42 INFO (SyncWorker_2) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:04:45 INFO (SyncWorker_2) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:05:11 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-01-29 16:05:11 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:05:12 INFO (SyncWorker_7) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:05:14 INFO (SyncWorker_7) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:05:27 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:05:27 INFO (SyncWorker_8) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:05:30 INFO (SyncWorker_8) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:05:56 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:05:57 INFO (SyncWorker_5) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:05:59 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:06:12 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:06:12 INFO (SyncWorker_10) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:06:15 INFO (SyncWorker_10) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:06:26 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:06:27 INFO (SyncWorker_2) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:06:29 INFO (SyncWorker_2) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:06:42 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:06:42 INFO (SyncWorker_13) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:06:44 INFO (SyncWorker_13) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:06:57 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:06:57 INFO (SyncWorker_7) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:06:59 INFO (SyncWorker_7) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:07:12 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:07:12 INFO (SyncWorker_8) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:07:14 INFO (SyncWorker_8) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:07:27 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:07:27 INFO (SyncWorker_9) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:07:30 INFO (SyncWorker_9) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:07:57 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:07:57 INFO (SyncWorker_10) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:07:59 INFO (SyncWorker_10) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:08:12 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:08:12 INFO (SyncWorker_2) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:08:14 INFO (SyncWorker_2) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:08:42 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:08:42 INFO (SyncWorker_14) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:08:44 INFO (SyncWorker_14) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:08:57 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:08:57 INFO (SyncWorker_0) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:08:59 INFO (SyncWorker_0) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:09:27 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:09:27 INFO (SyncWorker_18) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:09:29 INFO (SyncWorker_18) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:09:42 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:09:42 INFO (SyncWorker_4) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:09:44 INFO (SyncWorker_4) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:09:57 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:09:57 INFO (SyncWorker_11) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:09:59 INFO (SyncWorker_11) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:10:11 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-01-29 16:10:11 INFO (SyncWorker_1) [hassio.docker.interface] Restart homeassistant/raspberrypi3-homeassistant
18-01-29 16:10:27 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:10:27 INFO (SyncWorker_14) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:10:30 INFO (SyncWorker_14) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:10:57 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:10:57 INFO (SyncWorker_16) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:10:59 INFO (SyncWorker_16) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:11:12 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:11:12 INFO (SyncWorker_18) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:11:15 INFO (SyncWorker_18) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:11:42 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:11:42 INFO (SyncWorker_6) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:11:44 INFO (SyncWorker_6) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:11:57 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:11:57 INFO (SyncWorker_12) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:11:59 INFO (SyncWorker_12) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:12:12 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:12:12 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:12:15 INFO (SyncWorker_3) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
18-01-29 16:12:42 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-01-29 16:12:42 INFO (SyncWorker_8) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-01-29 16:12:44 INFO (SyncWorker_8) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.62.0
hassio s info
    "result": "ok",
    "data": {
        "version": "0.84",
        "last_version": "0.84",
        "beta_channel": false,
        "arch": "armhf",
        "wait_boot": 5,
        "timezone": "Europe/Zurich",
        "addons": [
                "name": "Configurator",
                "slug": "core_configurator",
                "description": "Browser-based configuration file editor for Home Assistant.",
                "state": "started",
                "version": "0.2.5",
                "installed": "0.2.4",
                "repository": "core",
                "icon": false,
                "logo": false
                "name": "Samba share",
                "slug": "core_samba",
                "description": "Expose Hass.io folders with SMB/CIFS",
                "state": "started",
                "version": "3.0",
                "installed": "3.0",
                "icon": false,
                "logo": true
                "name": "SSH server",
                "slug": "core_ssh",
                "description": "Allows connections over SSH",
                "state": "started",
                "version": "3.0",
                "installed": "3.0",
                "icon": false,
                "logo": true
        "addons_repositories": []
hassio ho hardware
    "result": "ok",
    "data": {
        "serial": [
            "/dev/ttyAMA0"
        "input": [],
        "disk": [],
        "gpio": [
            "gpiochip0",
            "gpiochip100"
        "audio": {
            "0": {
                "name": "bcm2835 - bcm2835 ALSA",
                "type": "ALSA",
                "devices": {
                    "0": "digital audio playback",
                    "1": "digital audio playback"
hassio net info
    "result": "ok",
    "data": {
        "hostname": "hassio"
Gets even more interesting when I look in debug mode. I have no idea what this behaviour could be caused by.
hassio -d ha logs
DEBUG [CmdHomeassistant]: action->'logs', endpoint='logs', serverOverride->'', GET->'true', options->'', rawjson->'false', filter->''
DEBUG [ExecCommand]: basepath->'homeassistant', endpoint->'logs', serverOverride->'', get->'true', Options->'', Filter->'', RawJSON->'false'
DEBUG [GenerateURI]: basepath->'homeassistant', endpoint->'logs', serverOverride->''
DEBUG [RestCall]: data->'http://hassio/homeassistant/logs', GET->'true', payload->''
DEBUG [RestCall]: ResponseBody->'Traceback (most recent call last):
    sys.exit(main())
    sys.exit(main())
Did you try to restore a snapshot? Might be the quicker way to fix this…
Yes, unfortunately it seems that there is no way to restore a snapshot from SSH, and home assistant is not loading, which means I can’t access the hassio panel from the front-end. The configurator is working just fine, as is the supervisor it seems from the logs.
This has basically become an experiment in how many weird responses I can get. I don’t know what’s going on with the below.
I’ve managed to update to 0.62.1 without a hitch. supervisor logs still show it trying to restart home assistant every 15-30 seconds, with the warning “Watchdog found a problem with the home assistant docker”.
I have a feeling I may be dealing with some corrupt files.
hassio ha -f result check
panic: interface conversion: interface {} is nil, not map[string]interface {}
goroutine 1 [running]:
github.com/home-assistant/hassio-cli/command/helpers.FilterProperties(0x107e0000, 0x6b9, 0xe00, 0x10764780, 0x1, 0x1, 0x1, 0xe00, 0xd53b0)
	/home/ryanm/go/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:122 +0x304
github.com/home-assistant/hassio-cli/command/helpers.ExecCommand(0x2ad793, 0xd, 0x7ea4de81, 0x5, 0x0, 0x0, 0x1076c100, 0x0, 0x0, 0x7ea4de7a, ...)
	/home/ryanm/go/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:148 +0x1a8
github.com/home-assistant/hassio-cli/command.CmdHomeassistant(0x107bc2c0)
	/home/ryanm/go/src/github.com/home-assistant/hassio-cli/command/homeassistant.go:48 +0x1a0
github.com/urfave/cli.HandleAction(0x262970, 0x2bd048, 0x107bc2c0, 0x0, 0x1076c1b0)
	/home/ryanm/go/src/github.com/urfave/cli/app.go:503 +0x64
github.com/urfave/cli.Command.Run(0x2ad793, 0xd, 0x0, 0x0, 0x3f53d8, 0x1, 0x1, 0x2b89f6, 0x2f, 0x0, ...)
	/home/ryanm/go/src/github.com/urfave/cli/command.go:165 +0x3b8
github.com/urfave/cli.(*App).Run(0x10770380, 0x1076c060, 0x5, 0x6, 0x0, 0x0)
	/home/ryanm/go/src/github.com/urfave/cli/app.go:259 +0x52c
main.main()
	/home/ryanm/go/src/github.com/home-assistant/hassio-cli/main.go:22 +0x184
You don’t save the snapshots to a different location?
Good point. I couldn’t get Samba to work on this install actually. But I will figure this out now and backup my snapshots.
that s what i really would love to do. How and where do you save them?
Thanks!
Marius
you need samba, they should be in the backup folder there.
yes i can find them in the backup folder, but would really like to safe them on another drive, in case the flash card dies.
I create manual backups , but it would really be nice if one could automatically have the HA system read/write these backups elsewhere.
I just move them by hand. But it might be possible to have some sort of automated snapshot routine… I’m just not the one to ask how :slight_smile:
I’m seeing exactly the same issue on Hassio after I initiated the update from version 0.62.1 to 0.63.3.
From what I can conclude from this thread, the fastest is to just reinstall Hassio and restore my configuration?
I just had the same issue, I activated trackers:
  • bluetooth (incl Bluetooth BCM43xx addon)
  • nmap
  • tomato router
After that hassio WebUI was unable to start. I was able to restore a snapshot from ssh shell:
  • To get a list of snapshots: hassio snapshots list
  • To restore one: hassio snapshots restore --name xyz
It worked with the slug name of the snapshot.
