After upgrading to 2026.4.4 on Saturday morning it did not come backup. Uh-oh. I stewed over it during the weekend and plugged it into a monitor this morning and the screen would not come up. Luckily, I had a 4B 16GB spare and moved the MicroSD card to it. As it booted, it started screaming about certain sectors on the MicroSD card…so I got a 2 for 1 boo-boo. Not going to blame the update. It was just luck of the draw. Parts have Mean Time Between Failures.
So I am at a crossroads: Go docker or go Raspberry PI 5.
I have a QNAP TVS-h1688X that is currently running a Windows Server VM and in the past I did run a docker of Pi-Hole that I removed after I got my bigger and more functional business class firewall that did what Pi-Hole did. I have tagged VLANs so I have my IoT VLAN (VLAN 253) going to it but I am not sure how to tag the docker VLAN for HA to use VLAN 253. I am going to ask QNAP about that. Then, I would have to convert my Z-Wave and Zigbee adapters to either be USB over IP or replace them with IP ones. Not opposed to doing that. It just seems like a lot of work. The hardware is clearly a single point of failure but I do not have the resources, yet, to build two or three Proxmox or other virtual hosts to allow containers to trade back and forth between them plus, it really bothers me that the device has a single power supply. I am used to enterprise servers with dual everything…just hate it when I have to pay for it. This NAS is running 96GB of memory, dual 4TB M.2 drives in RAID for the OS, dual 4TB SSDs drives for the VMs and containers, dual 4TB SSDs for caching and 12 18TB platters for storage in RAID6 with a hot spare…all drives Wester Digital Reds so it is no slouch. The VMs are running on the LACP teamed 2.5GB adapters running at 1GB each because my switch does not have four 2.5GB ports available but, the dual 10GB ports are teamed up in LACP for Plex and file storage. It screams.
Or…
I could buy a Raspberry PI5 but I would want to outfit it with DUAL M.2 drives in a RAID1 (mirror) setup AND run int PoE as my Cisco switch can supply up to 30-Watts on each port. I have one with a single M.2 drive and PoE HAT but that HAT cannot seem to negotiate with the switch that it needs more than 15.4-WATTs and I have to hard-set it in the switch to tell it to give the device the full 30-Watts. That is running my Ubiquity server for my access points and a headless PlexAmp for holiday music. I was thinking about building another one of those for Retro-Pi video games but the PoE+ negotiation spooks me.
Looking for advice on HATs if I go that option. I have seen a few dual M.2s but no PoE so that might be a second HAT? Theoretically, I could replace the Raspberry PI5 if it ever died by just moving the HATs and drives like you could do with a MicroSD card so the single point of failure on that is not too bad. Can HA support RAID1? Trying not to have it run on an external power supply if at all possible because the PoE on the switch is supplied by the switch’s dual power supplies PLUS UPSes on each power supply.
Willing to pay for help as far as setting up the docker option if anyone knows anyone if that is my best option. It seems like the option that would allow me to move it to new hardware in the future if that ever became a possibility.
Some important things I do have in my environment are: Z-Wave, Zigbee, Govee, Tempest Weather Station, Davis Technologies weather station, KASA power strips over WiFI, Sense, Ring, NVDIA Shield, Plex.
Since I basically have to start from brand new, given it your environment, those with a ton of experience, what would you do? I am looking for a consensus.
