I see in the documentation for the Wemo Integration:
Note: Due to the way that long press events are received by Home Assistant, modifying any of the Rules through the WeMo app can cause long press events to stop working until Home Assistant is restarted. Home Assistant modifies the local device’s rules database to enable long press event support. This local modification is not synchronized with the cloud service. Any rule changes from the cloud service (via the app) will likely overwrite the local changes made by Home Assistant.
Is there any way to get the Wemo integration to overwrite the local rules from time to time so I don’t need to Restart Home Assistant?
