Wemo switch turn on as script doesn't wok
Folks,
try to switch on a wemo switch which works in the GUI via script. What I tried is:
TEE anschalten
TEE_On:
alias: “Turn on Tee switch”
sequence:
- service: homeassistant.turn_on
entity_id: switch.tee
TEE ausschalten
TEE_On:
sequence:
- service: homeassistant.turn_off
What is wrong here?
When you post YAML, be sure to preformat it so that we can spot errors. Indentation is significant,
Something to try: Lower-case the script name. I’ve seen cases where people run into case issues with how things work internally in HASS
tee_on:
  alias: "Turn on Tee switch"
  sequence:
Thanks. I will gibe a try
