Hello there.
I’ve recently built a home thermostat for my heating system. It has at its base a chinese D1 Mini replica, a 5V relay, a 5V display connected to I2C (1306 i guess is the model), a temperature&humidity 3V (HDC1080) sensor and a 5V rotary encoder.
I have them connected in the following manner:
The Display is connected to the 5V on the board (i2c for data)
The temperature sensor is connected to the 3V pin on the board (i2c for data)
The relay is connected to the 3V pin on the board (the 5V one doesn’t seem to work is this case and GPIO for data)
The rotary encoder is connected to the 5V pin (GPIO for data).
The weird thig is: if i leave the rotary encoder plugged the Wemos will get random disconnects and becomes unavailable for a few seconds (3 or 5 disconnects in 60 minutes)
Ive checked the logs but i cannot seems to find anything that can point me to solving this. The only solution that ive found for now is to unplug the 5V power pin to the rotary. If i do this the thermostat works as expected.
Also i use a 5V 1A power supply and the current draw is something like 0.08A, so i don’t think its a power supply issue.
My question is: do you guys know of a limitation of the D1Mini to supply power to multiple sensors from its pins? That would explain why the board is getting disconnected (maybe the WIFI gets starved of power? idk.).
Any replay is appreciated, thanks!
