Wemos S3 mini esp-idf i2s_audio
I have a Wemos esp32 s3 mini board setup using esp-idf but I’m having problems configuring media_player. My config:
i2s_audio:
  - id: i2s_out
    i2s_lrclk_pin: 44
    i2s_bclk_pin: 36
media_player:
  - platform: i2s_audio
    i2s_audio_id: i2s_out
    dac_type: external
    i2s_dout_pin: 35
    mode: mono
but when I try to install it it fails with error:
This feature is only available with frameworks [‘arduino’].
I know it works fine on arduino but for this project I want to use esp-idf. Is that feature not available in this framework or is there a different way of configuring it?
As clearly indicated by the error message you indicate the feature is not supported on framework you use :frowning:
