wESP32 how to setup
Hi everyone, I have a wesp32 i’d like to use for ble proxy. Can anyone offer some assistance to get the ethernet working? I figured I could just do a generic proxy install from the web tool, then edit the yaml from the addon to turn off wifi and setup ethernet. When I try that it doesn’t like the ethernet code. I barely know what I’m doing with this stuff so please take it easy on me.
Thanks,
Can you explain it to me like I’m 5? I only know enough to be dangerous haha. That is what I’ve been trying to use. Is putting it in the editor through esphome addon the correct way to do this? When I try it tells me wifi and ethernet cannot be used at the same time, even if i delete the wifi. If i check if with the validator it gives an error and won’t compile.
