I just bought a new case for my rasbperrypi4. I ran the command “sudo shutdown” on my console and waited for putty to close the connection, after a few seconds and went over to my pi and unplugged it, put it into the new case and replugged everything. Unfortunately my pi4 now does not work correctly anymore. It does not connect to the network (via ethernet) anymore. I can see that my router sees the device on port4, but it does not get an ip from my router. Unfortunately I have no minihdmi to connect a monitor here, so without a network I seem a bit lost. But maybe some has a few ideas.
My setup is Rasbian Buster, my SD loads everything from an SSD that is connected via USB 3.0. I was thinking maybe I pulled the plug too early and “destroyed” my SD/SSD, but wouldn’t my pi then still obtain an ip?
So I checked the SSD and apparantly I messed up the fs. I reflashed the SSD and set everything up again, but now I cannot SSH into my os…
I’ve done this before so I don’t know why it’s not working this time. I SSH into my pi (booting from SD), change the boot to my SSD, reboot - I can see that it’s working because I can ping my pi - but then when I try to SSH into my pi (SSD) I get a “connection refused”. I double checked: the SSH file is on the /boot/ from my SSD.
the os removes the ssh file as soon as it has booted for the first time, or? because when I checked the SSD the ssh file was still in /boot/… I guess as long as I don’t have my hdmi cable here I won’t be able to know what is going on… Although none of this makes sense to me. I’m going to run off my sd as long as I have no idea what is going on.
Also SSHd is disabled by default on a Pi now, so if you connect a keyboard and login blind, you should be able to issue the command: sudo systemctl start sshd it should work as long as you keep track of your keystrokes
The thing is that I have the ssh file on the SSD… so… I still don’t know why it isnt working… tomorrow my cable will arrive. Either it’s just a stupid little thing that I missed or it won’t help at all
I still don’t know what I did wrong, but I used a script from this site to boot from my SSD which worked perfectly:
#!/bin/bash
trap '{ stty sane; echo ""; errexit "Aborted"; }' SIGINT SIGTERM
BOOTBEG=8192
BOOTEND=532480
ROOTBEG=540672
MNTPATH="/tmp/usb-boot-mnt"
mntusb()
MNTED=TRUE
if [ ! -d "${MNTPATH}/" ]; then
mkdir "${MNTPATH}/"
if [ $? -ne 0 ]; then
errexit "Unable to make ROOT partition mount point"
fi
fi
mount "${USB_ROOT}" "${MNTPATH}/"
errexit "Unable to mount ROOT partition"
fi
if [ ! -d "${MNTPATH}/boot/" ]; then
mkdir -p "${MNTPATH}/boot/"
errexit "Unable to make BOOT partition mount point"
fi
fi
mount "${USB_BOOT}" "${MNTPATH}/boot/"
errexit "Unable to mount BOOT partition"
fi
umntusb()
umount "${MNTPATH}/boot/"
errexit "Unable to unmount BOOT partition"
fi
umount "${MNTPATH}/"
errexit "Unable to unmount ROOT partition"
fi
rm -r "${MNTPATH}/"
MNTED=FALSE
errexit()
echo ""
echo "$1"
echo ""
if [ "${MNTED}" = "TRUE" ]; then
umount "${MNTPATH}/boot/" &> /dev/null
umount "${MNTPATH}/" &> /dev/null
rm -rf "${MNTPATH}/" &> /dev/null
fi
exit 1
MNTED=FALSE
if [ $(id -u) -ne 0 ]; then
errexit "Must be run as root user: sudo $0"
fi
PGMNAME="$(basename $0)"
for PID in $(pidof -x -o %PPID "${PGMNAME}"); do
if [ ${PID} -ne $$ ]; then
errexit "${PGMNAME} is already running"
fi
done
rsync --version &> /dev/null
errexit "rsync not installed (run: apt-get install rsync)"
fi
BOOT_PART="$(mount | sed -n 's|^\(/dev/.*\) on /boot .*|\1|p')"
ROOT_PART="$(mount | sed -n 's|^/dev/\(.*\) on / .*|\1|p')"
ROOT_TYPE="$(blkid "/dev/${ROOT_PART}" | sed -n 's|^.*TYPE="\(\S\+\)".*|\1|p')"
ROOT_DEV="${ROOT_PART:0:(${#ROOT_PART} - 1)}"
if [ "${ROOT_DEV}" = "mmcblk0p" ]; then
ROOT_DEV="${ROOT_DEV:0:(${#ROOT_DEV} - 1)}"
fi
USBDEVS=($(ls -l /dev/sd? 2> /dev/null | sed -n 's|^.*\(/dev/.*\)|\1|p'))
if [ ${#USBDEVS[@]} -eq 0 ]; then
errexit "No available USB mass storage devices found"
fi
for i in ${!USBDEVS[@]}; do
USBDEVS[i]="${USBDEVS[i]} ${USBDEVS[i]} OFF"
done
if [ -b /dev/mmcblk0 ]; then
USESDC=TRUE
else
USESDC=FLASE
fi
if [[ "${USESDC}" = "TRUE" && "$(vcgencmd otp_dump | grep 17:)" = "17:3020000a" ]]; then
whiptail --backtitle "USB Boot" --title "USB Boot Method" --yesno "\nUse SD card to boot the USB device (recommended)?" 12 64
YESNO=$?
if [ ${YESNO} -eq 255 ]; then
errexit "Aborted"
elif [ ${YESNO} -ne 0 ]; then
USESDC=FALSE
fi
elif [[ "${USESDC}" = "FALSE" && "$(vcgencmd otp_dump | grep 17:)" != "17:3020000a" ]]; then
errexit "Not a Raspberry Pi 3B+ or a Raspberry Pi 3B with OTP set and no SD card present"
fi
USB_DEST="$(whiptail --backtitle "USB Boot" --title "USB Mass Storage Devices" --notags --radiolist \
"\nSelect the USB mass storage device to boot" 13 47 ${#USBDEVS[@]} ${USBDEVS[@]} 3>&1 1>&2 2>&3)"
if [[ $? -ne 0 || "${USB_DEST}" = "" ]]; then
errexit "Aborted"
fi
USB_BOOT="${USB_DEST}1"
USB_ROOT="${USB_DEST}2"
if [ "/dev/${ROOT_DEV}" != "${USB_DEST}" ];then
whiptail --backtitle "USB Boot" --title "Replicate BOOT/ROOT Contents" --yesno "\nReplicate BOOT/ROOT contents from /dev/${ROOT_DEV} to ${USB_DEST}?" 12 64
YESNO=$?
errexit "Aborted"
elif [ ${YESNO} -eq 0 ]; then
if [ $(mount | grep -c "^${USB_DEST}") -ne 0 ]; then
errexit "USB mass storage device in use (mounted)"
fi
whiptail --backtitle "USB Boot" --title "WARNING" --yesno "\nWARNING\n\nAll existing data on USB device ${USB_DEST} will be destroyed!\n\nDo you wish to continue?" 14 64
YESNO=$?
errexit "Aborted"
fi
echo ""
echo "Replicating BOOT/ROOT contents from /dev/${ROOT_DEV} to ${USB_DEST} (this will take a while)"
fdisk "${USB_DEST}" <<EOF &> /dev/null
p
o
n
p
1
${BOOTBEG}
${BOOTEND}
t
c
p
n
p
2
${ROOTBEG}
p
w
EOF
partprobe
mkfs.vfat "${USB_BOOT}" > /dev/null
errexit "Unable to create BOOT filesystem"
fi
dosfsck "${USB_BOOT}" > /dev/null
errexit "BOOT filesystem appears corrupted"
fi
if [ "${ROOT_TYPE}" = "f2fs" ]; then
mkfs.f2fs -f "${USB_ROOT}" > /dev/null
else
mkfs.ext4 -F -q -b 4096 "${USB_ROOT}" > /dev/null
fi
errexit "Unable to create ROOT filesystem"
fi
mntusb
mkdir "${MNTPATH}/dev/" "${MNTPATH}/media/" "${MNTPATH}/mnt/" "${MNTPATH}/proc/" "${MNTPATH}/run/" "${MNTPATH}/sys/" "${MNTPATH}/tmp/"
errexit "Unable to create directories"
fi
chmod a+rwxt "${MNTPATH}/tmp/"
rsync -aDH --partial --numeric-ids --delete --force --exclude "${MNTPATH}" --exclude '/dev' --exclude '/media' --exclude '/mnt' --exclude '/proc' \
--exclude '/run' --exclude '/sys' --exclude '/tmp' --exclude '/lost+found' --exclude '/etc/udev/rules.d/70-persistent-net.rules' \
--exclude '/var/lib/asterisk/astdb.sqlite3-journal' / "${MNTPATH}/"
if [[ $? -ne 0 && $? -ne 24 ]]; then
errexit "Unable to replicate BOOT/ROOT contents from /dev/${ROOT_DEV} to ${USB_DEST}"
fi
umntusb
echo ""
echo "BOOT/ROOT contents replicated from /dev/${ROOT_DEV} to ${USB_DEST}"
fi
fi
PTUUID="$(blkid "${USB_DEST}" | sed -n 's|^.*PTUUID="\(\S\+\)".*|\1|p')"
if [ "${USESDC}" = "TRUE" ]; then
while [ "$(blkid /dev/mmcblk0 | sed -n 's|^.*PTUUID="\(\S\+\)".*|\1|p')" = "${PTUUID}" ]
do
echo ""
echo "WARNING : SD card (/dev/mmcblk0) and USB device (${USB_DEST}) have the same PTUUID (${PTUUID}) : SD card will boot instead of USB device"
XXUUID="$(hexdump -n 4 -e '"%08X"' /dev/random | tr [A-Z] [a-z])"
echo ""
echo -n "Ok to change PTUUID on USB device (${USB_DEST}) to ${XXUUID} (y/n)? "
while read -r -n 1 -s answer; do
if [[ "${answer}" = [yYnN] ]]; then
echo "${answer}"
if [[ "${answer}" = [yY] ]]; then
break
else
break 2
fi
fi
done
echo ""
echo "Changing PTUUID on USB device (${USB_DEST}) to ${XXUUID}"
p
x
i
0x${XXUUID}
r
p
w
EOF
PTUUID="${XXUUID}"
done
mkdir "${MNTPATH}/"
fi
fi
mount "${BOOT_PART}" "${MNTPATH}/"
fi
sed -i "/^[[:space:]]*#/!s|^\(.*root=\)\S\+\(\s\+.*\)$|\1PARTUUID=${PTUUID}-02\2|" "${MNTPATH}/cmdline.txt"
rm -r "${MNTPATH}/"
else
errexit "No SD card present"
fi
fi
mntusb
sed -i "/^[[:space:]]*#/!s|^\(.*root=\)\S\+\(\s\+.*\)$|\1PARTUUID=${PTUUID}-02\2|" "${MNTPATH}/boot/cmdline.txt"
sed -i "/^[[:space:]]*#/!s|^\S\+\(\s\+/\s\+.*\)$|PARTUUID=${PTUUID}-02\1|" "${MNTPATH}/etc/fstab"
sed -i "/^[[:space:]]*#/!s|^\S\+\(\s\+/boot\s\+.*\)$|${BOOT_PART}\1|" "${MNTPATH}/etc/fstab"
sed -i "/dtoverlay=sdtweak,poll_once/d" "${MNTPATH}/boot/config.txt"
sed -i '1{/^$/d}' "${MNTPATH}/boot/config.txt"
if [ -f "${MNTPATH}/boot/wpa_supplicant.conf" ];then
mv "${MNTPATH}/boot/wpa_supplicant.conf" "${MNTPATH}/etc/wpa_supplicant/wpa_supplicant.conf"
fi
cat <<EOF > "${MNTPATH}/etc/sdc-boot"
#!/bin/bash
EOF
if [ "$(find ${MNTPATH}/boot/ -type f -iregex "${MNTPATH}/boot/ssh\(\.txt\)?" -print -delete)" != "" ]; then
cat <<EOF >> "${MNTPATH}/etc/sdc-boot"
update-rc.d ssh enable && invoke-rc.d ssh start
EOF
fi
cat <<\EOF >> "${MNTPATH}/etc/sdc-boot"
cp /usr/bin/raspi-config /tmp/raspi-config-usb-tmp
sed -i -E "s/mmcblk0p?/${ROOT_DEV}/" /tmp/raspi-config-usb-tmp
sed -i 's| resize2fs /dev/$ROOT_PART &&| ROOT_DEV=\\$(findmnt / -o source -n) \&\&\n resize2fs \\$ROOT_DEV \&\&|' /tmp/raspi-config-usb-tmp
/tmp/raspi-config-usb-tmp --expand-rootfs &> /dev/null
rm /tmp/raspi-config-usb-tmp
sed -i '/sdc-boot/d' /etc/rc.local
rm /etc/sdc-boot
shutdown --no-wall -r now
exit 0
EOF
chmod +x "${MNTPATH}/etc/sdc-boot"
sed -i 's|^exit 0$|/etc/sdc-boot\nexit 0|' "${MNTPATH}/etc/rc.local"
else
sed -i "/^[[:space:]]*#/!s|^\S\+\(\s\+/boot\s\+.*\)$|PARTUUID=${PTUUID}-01\1|" "${MNTPATH}/etc/fstab"
if [ $(grep -c dtoverlay=sdtweak,poll_once "${MNTPATH}/boot/config.txt") -eq 0 ]; then
sed -i '1s/^/dtoverlay=sdtweak,poll_once\n\n/' "${MNTPATH}/boot/config.txt"
fi
fi
umntusb
DEV_LIST=()
DEV_LIST+=/dev/mmcblk0
fi
DEV_LIST+=($(ls -l /dev/sd? 2> /dev/null | sed -n 's|^.*\(/dev/.*\)|\1|p'))
if [ ${#DEV_LIST[@]} -gt 1 ]; then
for i in ${!DEV_LIST[@]}; do
if [ ${i} -lt $((${#DEV_LIST[@]} - 1)) ]; then
j=$((i + 1))
while [ ${j} -lt ${#DEV_LIST[@]} ]; do
if [ "$(blkid "${DEV_LIST[i]}" | sed -n 's|^.*PTUUID="\(\S\+\)".*|\1|p')" = "$(blkid "${DEV_LIST[j]}" | sed -n 's|^.*PTUUID="\(\S\+\)".*|\1|p')" ];then
if [[ "${DEV_LIST[i]}" != "/dev/mmcblk0" || "${DEV_LIST[j]}" != "${USB_DEST}" ]]; then
echo ""
echo "WARNING : ${DEV_LIST[i]} and ${DEV_LIST[j]} have the same PTUUID : $(blkid "${DEV_LIST[i]}" | sed -n 's|^.*PTUUID="\(\S\+\)".*|\1|p')"
fi
fi
((j += 1))
done
fi
done
fi
echo ""
echo "SD card must remain in place to boot the USB device"
else
echo "SD card must be removed to boot the USB device"
fi
fi
echo ""
Jeeze thats a lot. I just wrote a new fresh image to the SD card, and deleted the other non boot partitions, copied my SSD boot folder over the one on the SDcard (I had made changes from stock) and then just modified the device it was booting from to ‘sda’ instead of ‘mmcblk0’ and it worked fine.
That’s what I did the last time (and this time - which for what ever reason did not work) and this is also what this script does. It also offers some extras though, like cloning the sd card to the ssd if you want.
