On my dashboard it looks like the item is unavailable
The actual device is available
Sometimes it happens after rebooting and the dashboard will never refresh unless I keep rebooting and then one day it works
That means that the entities you have on your dashboard and the ones you are seeing on the device page are not the same.
Compare the entity names in your dashboard vs the ones in your device page. You will probably see eg. switch.air_purifier
on one and switch.air_purifier_2
on the other.
If that’s the case, I suggest you search for issues on the Local Tuya Github and check how to fix the issue with your entity names changing.
They look the same
entities:
- entity: switch.humidifier
toggle: true
- entity: switch.air_purifier
toggle: true
- entity: switch.wii_u
toggle: true
And then in the local tuya device
But are you sure the switches on your dashboard are unavailable? Do they work if you click on them?
Having a second look at your dashboard screenshot, it seems only dishwasher is actually unavailable, and I don’t see that listed in your devices page.
Yeah the dishwasher is not part of the Powerboard
You can’t click on dashboard but you can click in the tuya device
As I said every time you do a significant update this happens with Wi-fi devices and then I have to do a separate reboot and then it’s fine
Only thing I can think of which might cause this behaviour is browser cache, which needs to be cleared most times after an update.
Try clearing your browser cache (Ctrl+R or Ctrl+Shift+R in chrome, or Ctrl+F5 on all browsers)
A Tuya issue?
Can’t be if the same toggle behaves in the device screen. More likely, it’s cache.
