What does this freeze mean?
Whenever I startNnode Red I get this
7 Dec 09:58:23 - [info] [server:Home Assistant] Connected to http://supervisor/core
No error, but it always gets there in the log and then stops.
I deleted, renamed the remaining NR folder and then reinstalled Node Red from the add on store. Everything should be default.
I did try to install Tail Scale from the community add on store though yesterday (a decentralised VPN), which is when my problems with Node Red Started. It is now unistalled though.
Pretty sure the core updated yesterday, but after the problem started.
And I was just reading the settings.js file and it said
“ If you like to change those settings, some are available via the add-on
  • settings/option in the Supervisor panel in Home Assistant.
    I was trying to figure out how to start in safe mode, but what is a “supervisor panel”?
