Logger: zigpy.zcl
Source: runner.py:154
First occurred: 06:51:54 (1 occurrences)
Last logged: 06:51:54
[0x1592:1:0x0020] Traceback (most recent call last): File “/usr/local/lib/python3.13/site-packages/zigpy/device.py”, line 381, in request return await req.result ^^^^^^^^^^^^^^^^ asyncio.exceptions.CancelledError The above exception was the direct cause of the following exception: Traceback (most recent call last): File “/usr/local/lib/python3.13/site-packages/zigpy/zcl/init.py”, line 378, in request return await self._endpoint.request( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ …<9 lines>… ) ^ File “/usr/local/lib/python3.13/site-packages/zigpy/endpoint.py”, line 270, in request return await self.device.request( ^^^^^^^^^^^^^^^^^^^^^^^^^^ …<11 lines>… ) ^ File “/usr/local/lib/python3.13/site-packages/zigpy/device.py”, line 380, in request async with asyncio_timeout(timeout): ~~~~~~~~~~~~~~~^^^^^^^^^ File “/usr/local/lib/python3.13/asyncio/timeouts.py”, line 116, in aexit raise TimeoutError from exc_val TimeoutError The above exception was the direct cause of the following exception: Traceback (most recent call last): File “/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/general.py”, line 630, in check_in_response await self.checkin_response(True, self.CHECKIN_FAST_POLL_TIMEOUT, tsn=tsn) File “/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/init.py”, line 85, in wrapper with wrap_zigpy_exceptions(): ~~~~~~~~~~~~~~~~~~~~~^^ File “/usr/local/lib/python3.13/contextlib.py”, line 162, in exit self.gen.throw(value) ~~~~~~~~~~~~~~^^^^^^^ File “/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/init.py”, line 70, in wrap_zigpy_exceptions raise ZHAException(“Failed to send request: device did not respond”) from exc zha.exceptions.ZHAException: Failed to send request: device did not respond
Where do I look and what for? It doesn’t even identify the device that is the issue.
