What is the right way to call a Homeassisant service from ESPHome lambda code?
The latest esphome 2025.8.0 seems to have broken my lambda code that I used to turn on and off a Kasa plug (and worked 2 weeks ago)
              esphome::api::HomeassistantServiceResponse resp; // Call the service via C
              resp.service = "switch.turn_off";
              esphome::api::HomeassistantServiceMap data;
              data.key = "entity_id";
              data.value = "${filter_plug_entity}";
              resp.data.push_back(data);
              id(ha_api).send_homeassistant_service_call(resp);
With error:
/config/esphome/Wen3417Remote.yaml: In lambda function:
/config/esphome/Wen3417Remote.yaml:496:16: error: 'class esphome::api::HomeassistantServiceResponse' has no member named 'service'; did you mean 'set_service'?
  496 |               resp.service = "switch.turn_off";
      |                set_service
/config/esphome/Wen3417Remote.yaml:498:16: error: 'class esphome::api::HomeassistantServiceMap' has no member named 'key'
  498 |               data.key = "entity_id";
I tried a newer approach like:
              esphome::api::CustomAPIDevice api;
              api.call_service("switch", "turn_off", {{"entity_id", "${filter_plug_entity}"}});
But that and variations gave errors like:
/config/esphome/Wen3417Remote.yaml:496:15: error: 'class esphome::api::CustomAPIDevice' has no member named 'call_service'
  496 |               api.call_service("switch", "turn_off", {{"entity_id", "${filter_plug_entity}"}});
Trying:
              id(ha_api).call_service("switch.turn_off", {{"entity_id", "${filter_plug_entity}"}});
gave similar errors.
There must be a simple way to call a service from lambda code as that seems like a very basic thing to do but I can’t figure out how…
(NOTE: I know I could try to do this all in yaml, but I have a complex sequence of service calls and associated manipulations
that is simpler to do all in C)
The proble with accessing ESPHome internals directly is that they can change without notice. I have been caught out before as well.
Looks like that function changed for 2025.8:
https://api-docs.esphome.io/classesphome_1_1api_1_1_homeassistant_service_response.html
hello,
same boat :
/config/esphome/digicode.yaml:1141:24: error: 'class esphome::api::HomeassistantServiceMap' has no member named 'key'
 1141 |               entity_id_kv.key = "position";
/config/esphome/digicode.yaml:1151:16: error: 'class esphome::api::HomeassistantServiceResponse' has no member named 'service'; did you mean 'set_service'?
 1151 |               resp.service = "cover.set_cover_position";
      |                set_service
please, i dont understand what to do exactly?
resp.set_service
doesnt work
I’m on the same boat, everything is broken after 2025.8.0.
/config/esphome/common/sonoff-m5/m5-3c-86/binary_sensor.yaml: In lambda function:
/config/esphome/common/sonoff-m5/m5-3c-86/binary_sensor.yaml:22:9: error: 'HomeassistantServiceResponse' was not declared in this scope
   22 |               HomeassistantServiceResponse svc;
/config/esphome/common/sonoff-m5/m5-3c-86/binary_sensor.yaml:23:9: error: 'svc' was not declared in this scope
   23 |               svc.service = "pyscript.switch_single_click";
/config/esphome/common/sonoff-m5/m5-3c-86/binary_sensor.yaml:25:9: error: 'HomeassistantServiceMap' was not declared in this scope
   25 |               HomeassistantServiceMap ent;
/config/esphome/common/sonoff-m5/m5-3c-86/binary_sensor.yaml:26:9: error: 'ent' was not declared in this scope; did you mean 'int'?
   26 |               ent.key = "ls_eid";
      |         int
/config/esphome/common/sonoff-m5/m5-3c-86/binary_sensor.yaml:29:28: error: 'class esphome::api::APIServer' has no member named 'send_homeassistant_service_call'
   29 |               global_api_server->send_homeassistant_service_call(svc);
My code as follows
          ent.key = "ls_eid";
          ent.value = "binary_sensor.${eid}_left_button";
          svc.data.push_back(ent);
I’m not really familiar with C++, but am I suppose to change it to this?
esphome::api::HomeassistantServiceResponse svc;
svc.set_service("pyscript.switch_single_click");
esphome::api::HomeassistantServiceMap ent;
ent.set_key("ls_eid");
My builds were also broken after updating 2025.8.0, but thankfully the changes are not too significant and got this working after looking at the docs. You’re almost there, here’s your code where I updated the args passed to the set_* functions to use the StringRef type:
svc.set_service(esphome::StringRef("pyscript.switch_single_click"));
ent.set_key(esphome::StringRef("ls_eid"));
Thanks, it’s working, note that homeassistant_services: true in api: need to be added to make it work.
You can also simplify it by removing the namespace
          svc.set_service(StringRef("pyscript.switch_single_click"));
          ent.set_key(StringRef("ls_eid"));
I also fixed it using a modified version based on the new api
              resp.set_service(esphome::StringRef("switch.turn_off"));
              data.set_key(esphome::StringRef("entity_id"));
Wish breaking changes like this would have been documented.
I am having a similar issue (HA 2026.1.2, ESPHome 2025.11.0). I can successfully trigger a switch via esphome if I do the standard yaml method, but I cannot get it working with a lambda.
Example esphome lambda:
script:
  - id: power_select
    parameters:
      outlet: int
      state: int
    then:
      - lambda: !lambda |
          ESP_LOGI("main", "Power_select invoked, outlet %d action %d", outlet, state);
          HomeassistantActionRequest svc;
          ent.set_key(StringRef("entity_id"));
          ent.value = StringRef("switch.tp_link_power_strip_b54b_plug_1");
          svc.set_service(StringRef("switch.turn_on"));
          id(api_server)->send_homeassistant_action(svc);
The home assistant logs show that it isn’t receiving a proper entity_id:
2026-01-20 10:55:44.517 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (task: None)
  File "/usr/local/lib/python3.13/site-packages/voluptuous/schema_builder.py", line 205, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.13/site-packages/voluptuous/schema_builder.py", line 779, in validate_callable
    return schema(data)
  File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 227, in validate
    raise vol.Invalid(f"must contain at least one of {expected}.")
voluptuous.error.Invalid: must contain at least one of entity_id, device_id, area_id, floor_id, label_id.
  File "/usr/src/homeassistant/homeassistant/core.py", line 2784, in async_call
    processed_data: dict[str, Any] = handler.schema(service_data)
  File "/usr/local/lib/python3.13/site-packages/voluptuous/validators.py", line 259, in __call__
    return self._exec((Schema(val) for val in self.validators), v)
  File "/usr/local/lib/python3.13/site-packages/voluptuous/validators.py", line 386, in _exec
    raise e if self.msg is None else AllInvalid(self.msg, path=path)
  File "/usr/local/lib/python3.13/site-packages/voluptuous/validators.py", line 382, in _exec
    v = func(v)
  File "/usr/local/lib/python3.13/site-packages/voluptuous/schema_builder.py", line 209, in __call__
    raise er.MultipleInvalid([e])
voluptuous.error.MultipleInvalid: must contain at least one of entity_id, device_id, area_id, floor_id, label_id.
I’m assuming my lambda is wrong somewhere, maybe the keyval schema is now different?
The interface has broken several times since my previous post from August
The following worked until 2025.08
HomeassistantActionResponse srvc; // Call the service via C (changed with 2025.08)
srvc.set_service(esphome::StringRef("switch.turn_off"));
srvc.data.push_back(data);
global_api_server->send_homeassistant_action(srvc);
After 2025.08, the following worked:
HomeassistantActionRequest srvc; // Call the service via C (changed with 2025.08)
After about 2025.10, the following worked:
srvc.data.init(1);  // Initialize exactly one data entry
auto &kv = srvc.data.emplace_back();
kv.set_key(StringRef("entity_id"));
kv.value = "${filter_plug_entity}";
Starting with 2026.01, the following worked:
srvc.service = StringRef("switch.turn_off");
kv.key = StringRef("entity_id");
kv.value = StringRef("${filter_plug_entity}");
So, yes the interface changed and broke 4 times in the last 6 months without any clear notice in the release notes.
In defense of the devs, this is not a “documented/stanard” user API.
On the other hand it should be a standard one since it seems like a very basic, helpful, and even necessary capability to call a HA service from lambda code, especially when you have a block of lambda code that calls various HA services (the only “sanctioned” alternative is to switch back and forth between yaml to call the services and lambda code to execute your C-code)
Thanks for the response, I ended up using that “sanctioned” alternative, peeling back some triggers into the yaml format and using lambda code there. I’ll come back here next time I refactor - hopefully a new version doesn’t come out in the meantime that breaks it again :sweat_smile:
