That automation will fire if a boolean is switched on and at the exact time it is switched on the time matches a predefined time in a sensor.
At the very least I suspect your trigger and condition are the wrong way round, other than that, without knowing what you’re trying to do, and without being able to see the formatting of your code, we’re shooting blindly in to the wilderness with a blunderbuss.
I tried using the </> but it still comes out like this. I know my indentation is correct, I do the hassio homeassistant check and it’s good but it just does not do anything when I restart.
Hey your help is appreciated. I am a newby at hassio, I saw this on an example on the homeassistant.io page and decided to try it. I thought if the hassio check shows ok, then all would be fine.
Best I can do is show you my fully working alarm clock package for my bedroom, which uses a time sensor, environmental data and presence data from elsewhere, but basically you set the time, and switch it on and then if we’re in it turns on the radio at the time specified and if its dark turns the lights on…
