I have a Unifi AP LR for my access point, but I need just a WIRED router that allows me to reserve the IP clients MAC address to it. Also I need it to have the ability to reserve many IP more than just the total number of wired ports that are on the actual router itself.
If you have a spare raspberry pi lying around you can install pihole and have it handle dhcp, but this is assuming you can turn off dhcp on your current router.
I set all my fixed IPs on my Synology when my Netgear router ran out of ‘space’.
In the meanwhile, I bought an Ubiquiti EdgeRouter and am very happy with it.
I’ve been thinking about moving the IP address handling onto it and one of these days, I will actually do it. Seems straightforward enough.
Thanks forsquirel for that tid-bit. I will look into that.
chairstacker, nice call on the Ubiquiti EdgeRouter. Since I have their Access Point unit I should have thought to look into theirs. But what I did however go with, was the “TP-Link SafeStream TL-R600VPN” router. For it can connect up to 256 DHCP clients. SWEEEEET!
