What would you choose for a PTZ camera in this use case?
I plan on installing and using Zoneminder, unless there’s something else out there that I should be looking at.
With that in mind, I need to find a selection of cameras (PoE, so Ethernet port needed) that would be good for our warehouse/business.
I’d like to be able to move them and set up motion sensing zones on each one, as well as have a few static cameras that never move. They will all be indoor cameras.
What would you choose if you needed to keep each camera in the $100 - $200 range?
Check Hikvision
Hikvision don’t seem to have cameras that are PTZ in lower cost range. Amcrest is PTZ with onvif support in that price range. Instar and dahua are brands also worth checking out if not in the USA.
