Whats is going on with development? Stability please?
Reconsidered and rewrote.
This has been rehashed so many times... The people here don't work for Home Assistant, that's an open source project run by the Open Home Foundation. We are, predominantly, just fellow users volunteering our time to help others.
Additionally,
  • No one here forced you to update the first week of the month.
  • No one here forced you to update without understand what "some update to tuya" actually was.
  • No one here forced you to use Tuya-based products.
  • No one here forced you to use a custom integration that is not under the control of Home Assistant developers or the Open Home Foundation.
  • No one here forced you to set up your lights in the manner that you did.
You did all that. Please improve asap!
If you have an actual question, please review the Community Questions Guidelines, then post your question. We will try to help as best we can.
If you have a concrete issue with HA core, please create an issue on the repo. Issues with custom integrations should be posted to their repos.
I, too, had to learn the hard way to read the release notes and, also, that custom integrations are subject to chaos during major releases.
