it seems there is no french (or dutch) version of
https://assistant.google.com/services/a/uid/00000091fd5fb875?hl=en-US
(https://assistant.google.com/u/1/explore/c/19/?hl=fr-FR)
Does anyone has the corresponding french keywords?
regarding the use of custom commands, is it correct those have to be created manually as ‘routine’ in Google assistant?
Is there a way to keywords form the commands like ‘dans’,‘à’,‘au’,‘le’,‘la’,‘les’,‘l’,’’’,‘lumière’,‘lumières’,‘du’,‘des’,‘de’,‘sur’
that sometimes are added and eventually refer to the same light… ?
Where can I troubleshoot and see the commands sent from Google -> Home asssitant?
In the logs I can find errors,.
When sending a command on a group of lights (via mochad X10)I have the same (timeout?) issue, like Google Home unknown error?
‘something went wrong’ , (erreur inconnue)
tx!
