What's up with deCONZ/Phoscon in Safari?
Just noticed another problem with HA related to Safari on Mac. I cannot access Phoscon web page :frowning:
When I try to access deCONZ integration web page, I’m presented with standard deCONZ or Phoscon choice. deCONZ works perfectly, as it was up too now. But when I select Phoscon, instead of getting to gateway selection I get empty page. I tried to reload add-on and integration. I even restarted HA, but nothing helps. The problem is only present in Safari (at least on Mac). I tried with Edge (on Mac) and in Windows and everything works fine. It looks like gradually we have more and more issues with Safari on Mac.
Not sure when it was introduced, as I’m not frequently reaching to Phoscon UI. Not sure if this is add-on issue (introduced with some recent update) or HA - then introduced probably with 2026.1.x
Anyone face similar issue? Any solution?
Update on this; it is happening only when accessing HA using external URL, routed through reverse proxy to internal IP/port. When accessing internally using IP or mDNS it works fine. I hit this problem as I routinely use external URL everywhere. Anyhow something changed…
