Whats wrong with my config? input_datetime unavailable!
Despite having an entry in my configuration.yaml for “default_config:” I’m getting these errors.
Also, when I check my configuration it reports as being valid.
Any idea?
There is something wrong with where or how you have defined default_config. Show your (sanitised) config for help with this.
In the Configuration.yaml file
I would # the Input_datetime bits
#  last_rain:
 #   name: Time of last reported rainfall
 #   has_date: true
 #   has_time: true
do a Configuration check and a reboot and see if you still getting same errors
added the configuration.yaml
nothing fancy, pretty basic really
Next thing to look at is your input_datetime config (copy and paste, not screenshot).
surround your pasted code in three backticks like this to format it propertly
oh sorry about that.
not sure I understood, there’s nothing more, that’s the whole configuration.yaml
this is a windows/python server if that makes any difference
The notification only tells you there was a problem, not what problem.
Most likely there will be more details in the logfile.
Either via the interface, development tools -> logs or otherwise, check the file home-assistant.log next to configuration.yaml
here:
2020-05-29 14:58:43 ERROR (MainThread) [homeassistant.setup] Error during setup of component input_datetime
  File "C:\Users\Joaquim\AppData\Local\Programs\Python\Python38\lib\site-packages\homeassistant\setup.py", line 170, in _async_setup_component
    result = await component.async_setup(  # type: ignore
  File "C:\Users\Joaquim\AppData\Local\Programs\Python\Python38\lib\site-packages\homeassistant\components\input_datetime\__init__.py", line 113, in async_setup
    await storage_collection.async_load()
  File "C:\Users\Joaquim\AppData\Local\Programs\Python\Python38\lib\site-packages\homeassistant\helpers\collection.py", line 172, in async_load
    await self.notify_change(CHANGE_ADDED, item[CONF_ID], item)
  File "C:\Users\Joaquim\AppData\Local\Programs\Python\Python38\lib\site-packages\homeassistant\helpers\collection.py", line 111, in notify_change
    await listener(change_type, item_id, item)
  File "C:\Users\Joaquim\AppData\Local\Programs\Python\Python38\lib\site-packages\homeassistant\helpers\collection.py", line 269, in _collection_changed
    await entity_component.async_add_entities([entity])
  File "C:\Users\Joaquim\AppData\Local\Programs\Python\Python38\lib\site-packages\homeassistant\helpers\entity_platform.py", line 295, in async_add_entities
    await asyncio.gather(*tasks)
  File "C:\Users\Joaquim\AppData\Local\Programs\Python\Python38\lib\site-packages\homeassistant\helpers\entity_platform.py", line 445, in _async_add_entity
    entity.async_write_ha_state()
  File "C:\Users\Joaquim\AppData\Local\Programs\Python\Python38\lib\site-packages\homeassistant\helpers\entity.py", line 297, in async_write_ha_state
    self._async_write_ha_state()  # type: ignore
  File "C:\Users\Joaquim\AppData\Local\Programs\Python\Python38\lib\site-packages\homeassistant\helpers\entity.py", line 323, in _async_write_ha_state
    attr.update(self.state_attributes or {})
  File "C:\Users\Joaquim\AppData\Local\Programs\Python\Python38\lib\site-packages\homeassistant\components\input_datetime\__init__.py", line 329, in state_attributes
    attrs["timestamp"] = self._current_datetime.timestamp()
OSError: [Errno 22] Invalid argument
2020-05-29 14:58:45 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: input_datetime
2020-05-29 14:58:45 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
Anyone there?
Still waiting for some help please!
The log file clearly shows that Home Assistant failed to load the module that implements input_datetime. That explains why input_datetime is unavailable for use. However, the deeper question is why did it fail to load the input_datetime module? This line seems to be the key but, unfortunately, I don’t understand its cause:
Thanks,
Is there anything I can try before reinstalling the whole thing?
Unfortunately, due to my unfamiliarity with the root-cause of this issue, I’m in no position to offer advice.
All I can say is that if I were in the same position, I would also consider re-installing it.
I’ve fixed it!
After a bit of digging in homeassistant internals, I found an ‘input_datetime’ file inside ‘.storage’ folder.
I’ve opened it with a text editor and inside was an old configuration I did some time ago, that was the root cause of the issue.
Once I deleted this file, the startup notification is gone and the helper is again available.
Thank you all for your time.
That file is created when you define an input_datetime via Configuration > Helpers. Its mere presence is not the ‘root cause’. The file will re-created when you define your next input_datetime. The problem may have been due to data corruption (i.e. the file’s contents were not in proper format).
Were you able to observe if it was valid JSON format?
yes, you’re absolutely right, it gets re-created and the issue is back :frowning:
I can’t evaluate its correctness but leave it here for you to have a look:
    "data": {
        "items": [
                "has_date": true,
                "has_time": true,
                "icon": "mdi:timer",
                "id": "timer",
                "name": "Timer"
                "has_date": true,
                "has_time": true,
                "id": "timer_2",
                "name": "timer"
                "has_date": true,
                "has_time": true,
                "id": "timer_3",
                "name": "Timer"
                "has_date": false,
                "has_time": true,
                "id": "timer_4",
                "name": "Timer"
    "key": "input_datetime",
    "version": 1
