Hi everybody,
I have developed a little template sensor, which shows me, when it’s time to open the windows and get some fresh air into our house. It is based on several other air quality and climate sensors.
I have tried to come up with a set of rules that
- make sure the humidity does not get too high in the house
- radiation based on Radon does not get too high
- insight temperature should not get too high in summer
This is, how it looks like in my dashboard. (-> based on mushroom cards)
this is the yaml of the card
type: vertical-stack
cards:
primary: "{{states('sensor.dachzimmer_lueften')}}"
secondary: ""
icon: " {{ state_attr('sensor.dachzimmer_lueften', 'icon') }}"
entity: sensor.dachzimmer_lueften
tap_action:
action: more-info
color: " {{ state_attr('sensor.dachzimmer_lueften', 'color') }}"
features_position: bottom
- type: horizontal-stack
cards:
primary: ""
secondary: >-
{% set radon = int(states('sensor.esphome_dachzimmer2_radon'), 'Sensor
Wert fehlt') %}
{% if is_number( radon ) %}
{{ radon }} Bq/m³
{% else %}
{{ radon }}
{% endif %}
icon: mdi:radioactive
entity: sensor.esphome_dachzimmer2_radon
tap_action:
action: more-info
color: >-
Wert fehlt') %}
{% if radon <80 %}
green
{% elif radon <100 %}
amber
{% elif radon <125 %}
orange
{% elif radon <=150 %}
red
{% elif radon >150 %}
pink
{% endif %}
vertical: true
primary: ""
secondary: >-
{% set voc = int(states('sensor.esphome_dachzimmer2_voc'), 'Sensor
Wert fehlt') %}
{% if is_number( voc ) %}
{{voc}} ppb
{% else %}
{{voc}}
{% endif %}
icon: mdi:molecule
icon_color: >-
Wert fehlt') %}
{% if voc < 250 %}
green
{% elif voc < 1125 %}
amber
{% elif voc < 2000 %}
orange
{% elif voc <= 2875 %}
red
{% elif voc > 2875 %}
pink
{% endif %}
entity: sensor.esphome_dachzimmer2_voc
layout: vertical
tap_action:
action: more-info
primary: ""
secondary: >-
{% set co2 = int(states('sensor.esphome_dachzimmer2_co2'), 'Sensor
Wert fehlt') %}
{% if is_number(co2) %}
{{ co2 }} ppm
{% else %}
{{ co2 }}
{% endif %}
icon: mdi:molecule-co2
entity: sensor.esphome_dachzimmer2_co2
icon_color: >-
Wert fehlt') %}
{% if co2 < 800 %}
green
{% elif co2 < 900 %}
amber
{% elif co2 < 1000 %}
orange
{% elif co2 <= 1250 %}
red
{% elif co2 > 1250 %}
pink
{% endif %}
layout: vertical
badge_color: ""
badge_icon: ""
tap_action:
action: more-info
primary: ""
secondary: >-
{% set hum = float(states('sensor.esphome_dachzimmer2_feuchtigkeit'),
'Sensor Wert fehlt') %}
{% if is_number( hum ) %}
{{ hum | round(0) }} %
{% else %}
{{ hum }}
{% endif %}
icon: mdi:water-percent
entity: sensor.esphome_dachzimmer2_feuchtigkeit
tap_action:
action: more-info
color: >-
{% set dp_out = float(states('sensor.dew_point_at_8400'), 'Sensor Wert
fehlt') %}
{% set dp_in = float(states('sensor.esphome_dachzimmer2_taupunkt'),
{% if dp_out * 1.1 < dp_in and hum < 55 %}
green
{% elif dp_out * 1.1 < dp_in and hum < 60 %}
amber
{% elif dp_out * 1.075 < dp_in and hum < 65 %}
orange
{% elif dp_out * 1.05 < dp_in and hum <= 70 %}
red
{% elif dp_out * 1.05 < dp_in and hum > 70 %}
pink
{% else %}
disabled
{% endif %}
vertical: true
primary: ""
secondary: >-
{% set temp_in = float(
states('sensor.esphome_dachzimmer2_temperatur') | round(1), 'Sensor
Wert fehlt' ) %}
{% if is_number(temp_in) %}
{{ temp_in }} °C
{% else %}
{{ temp_in }}
{% endif %}
icon: mdi:thermometer
entity: sensor.esphome_dachzimmer2_temperatur
tap_action:
action: more-info
color: >-
states('sensor.esphome_dachzimmer2_temperatur'), 'Sensor Wert fehlt' )
{% set temp_out = float( states('sensor.temperature_at_8400'), 'Sensor
Wert fehlt' ) %}
{% if ( temp_in > 23.5 and temp_in > temp_out * 1.1 ) or ( temp_in <
19.5 and temp_out > temp_in * 1.1 ) %}
red
{% elif ( temp_in > 23.5 and temp_in > temp_out * 1.075 ) or ( temp_in
< 19.5 and temp_out > temp_in * 1.075 ) %}
orange
{% elif ( temp_in > 23.5 and temp_in > temp_out * 1.05 ) or ( temp_in
< 19.5 and temp_out > temp_in * 1.05 ) %}
amber
{% elif ( temp_in <= 23.5 and temp_in > 19.5 ) %}
green
{% elif temp_in == 'Sensor Wert fehlt' or temp_out == 'Sensor Wert
fehlt' %}
disabled
{% else %}
disabled
{% endif %}
vertical: true
this is the template sensor
### Dach: Sensor, der anzeigt, ob gelüftet werden soll. ###
- sensor:
- name: "Dachzimmer lüften"
unique_id: sensor.dachzimmer_lueften
state: >
{# Lüften-Sensor #}
{# Variablen definieren #}
{% set radon = int( states('sensor.esphome_dachzimmer2_radon'), 'Sensor Wert fehlt' ) %}
{% set voc = int( states('sensor.esphome_dachzimmer2_voc'), 'Sensor Wert fehlt' ) %}
{% set co2 = int( states('sensor.esphome_dachzimmer2_co2'), 'Sensor Wert fehlt' ) %}
{% set hum = float( states('sensor.esphome_dachzimmer2_feuchtigkeit'), 'Sensor Wert fehlt' ) %}
{% set dp_in = float( states('sensor.esphome_dachzimmer2_taupunkt'), 'Sensor Wert fehlt' ) %}
{% set dp_out = float( states('sensor.dew_point_at_8400'), 'Sensor Wert fehlt' ) %}
{% set temp_in = float( states('sensor.esphome_dachzimmer2_temperatur'), 'Sensor Wert fehlt' ) %}
{% set temp_out = float( states('sensor.temperature_at_8400'), 'Sensor Wert fehlt' ) %}
{# availability check #}
{% if 'Sensor Wert fehlt' in [ radon, voc, co2, hum, dp_in, dp_out, temp_in, temp_out ] %}
Sensor Wert fehlt
{% else %}
{# Lüften-Sensor berechnen #}
{% if ( radon >= 125 )
or ( voc >= 2000 )
or (
( hum > 70 or co2 >= 1000 or ( temp_in > 23.5 and temp_in > temp_out * 1.1 ) or ( temp_in < 19.5 and temp_out > temp_in * 1.1 ) )
and ( dp_out >=0 and dp_in > dp_out * 1.05 or dp_out < 0 and dp_in > dp_out * 0.95 )
Dach sofort lüften
{% elif ( radon >= 100 )
or ( voc >= 1125 )
or (
( hum > 65 or co2 >= 900 or ( temp_in > 23.5 and temp_in > temp_out * 1.075 ) or ( temp_in < 19.5 and temp_out > temp_in * 1.075 ) )
and ( dp_out >=0 and dp_in > dp_out * 1.075 or dp_out < 0 and dp_in > dp_out * 0.925 )
Dach lüften
{% elif ( radon >= 85 )
or ( voc >= 250 )
or (
( hum > 60 or co2 >= 800 or ( temp_in > 23.5 and temp_in > temp_out * 1.05 ) or ( temp_in < 19.5 and temp_out > temp_in * 1.05 ) )
and ( dp_out >=0 and dp_in > dp_out * 1.1 or dp_out < 0 and dp_in > dp_out * 0.9 )
Dach bald lüften
{% else %}
Dach nicht lüften
{% endif %}
{% endif %}
icon: >
{% if is_state('sensor.dachzimmer_lueften', 'Dach sofort lüften') or is_state('sensor.dachzimmer_lueften', 'Dach lüften') or is_state('sensor.dachzimmer_lueften', 'Dach bald lüften') %}
mdi:window-open-variant
{% elif is_state('sensor.dachzimmer_lueften', 'Dach nicht lüften') %}
mdi:window-closed-variant
{% elif is_state('sensor.dachzimmer_lueften', 'Sensor Wert fehlt') %}
mdi:alert-outline
{% else %}
mdi:help-circle-outline
{% endif %}
attributes:
color: >
{% if is_state('sensor.dachzimmer_lueften', 'Dach sofort lüften') %}
red
{% elif is_state('sensor.dachzimmer_lueften', 'Dach lüften') %}
orange
{% elif is_state('sensor.dachzimmer_lueften', 'Dach bald lüften') %}
amber
disabled
{% else %}
pink
{% endif %}
EDIT: new code further down: When to open windows based on air quality - #4 by schneich
(Please take my appologies for the german comments and sensors names.)
Let me know, what you think. Do you like it? Have you got a more elegant way to show something similar?
