Where are the KNX YAML files when using the built-in config tool?
I have used the built-in KNX configuration tool (from the KNX entry in settings); where are the resulting YAML files stores?
Hi :wave:!
The UI doesn’t create yaml files. The json used for that isn’t meant to be user-edited and isn’t compatible to the integrations yaml config format.
