After reading WebSocket API | Home Assistant Developer Docs I realized it doesn’t actually say what commands I can use.
For example /config/area_registry/list
will list all the areas but where is that documented?
I discovered this because I want to determine what integration a given entity id is from in a custom strategy. I went to go read the documentation to see what might contain integration info and realized there doesn’t appear to be any. Is this actually the case or have I just the worst google-fu today?
Edit: as it turns out for that initial use case, the entity
returned by “config/entity_registry/list” has a “platform” attribute. However, I am still very much interested in the documentation, if it exists.
