Where can I find a smart wall light switch that HA can control directly instead of a cumbersome Alexa Dot light switch unit that requires work arounds?
To assist in finding a product for you please supply:
Which protocols do you can use, zigbee, zwave, wifi?
Where in the world are you?
Also, does it need to be a wall switch or can it be a small device to be mounted behind the wall switch? The latter opens up way more options.
The latter: Tuya ZigBee 3.0 Smart Switch Module 200-240V No Neutral Wire Smart Home Automation Breaker 1/2/3/4 Gang Works with Alexa Google
IMPORTANT: please consult the experience before making such modifiation
They haven’t even said if they have zigbee yet.
I might need to use the best protocal for newbies?
I am in USA, NC.
I would like it to fit behind a regular light switch’s wall plate?
What is the best protocol for newbies with an existing WiFi available?
Shelly devices are pretty good and have perfect HA integration. They are available for Wifi, Bluetooth, Zigbee and Wave. And with existing Wifi available, I see no reason not to go for that.
For your use case, the red ones (“1PM”) are the right ones. The Minis are fine, they are extra small and have an 8 amp limit (900W). The smallness makes it easier to shove them behind wall switches and 900W should be plenty for lights.
Just out of curiosity, what is this
that you speak of?
That switch is 99% a Tuya device. There’s an integration for it, but I’d recommend you read up on Tuya first
I think the hardware is half of the puzzle, right now I am struggling with how it receive or intercept the SimpliSafe motion detection banners that I we currently receive on our smart phones, for use to trigger and action?
