Where can I find Tibber raw price forecast data in Home Assistant?
I’m using Home Assistant together with Tibber (electricity retailer) and Nord Pool spot prices in Sweden for a home-heating optimization project.
I am trying to build a predictive home-heating controller in Home Assistant.
So far I have identified:
T1 = sensor.per_s_device_current_temperature
(Hall temperature via Sensibo)
T2 = sensor.lumi_lumi_sensor_ht_agl02_temperature
(Kitchen temperature via Aqara)
Price_now = sensor.adress_electricity_price
Tout_now = weather.forecast_home.temperature
However, I cannot find:
• Historical electricity prices
• Future electricity prices (quarter-hourly)
• Historical consumption data
• Outdoor temperature forecast data
I checked:
Settings → Devices & Services → Tibber
and Home Assistant States/Entities.
The Tibber price sensor only exposes summary attributes such as min_price, max_price and avg_price, but not the underlying raw time series.
Note. On the iphone Tibber-App I can view the data I ask for and plot it, so they have the data.
Where can I access the raw historical and forecast data for electricity prices, consumption and weather forecasts inside Home Assistant?
Look for the action get_prices, it gives you all you need
The tibber.get_prices action is the right starting point for the forecast — it returns tomorrow’s prices as a list you can loop over in a script or template. Just keep in mind the timestamps come back in UTC, so convert them to your local timezone before matching them against your heating schedule. For the historical side, your long-term statistics (which the Energy dashboard already uses) hold prices and consumption going back as far as your recorder data does, so a statistics-based template sensor can cover T1/T2 comparisons and past costs. For the outdoor temperature forecast, the weather.get_forecasts action on your home weather entity gives you hourly forecast values you can template into sensors the same way.
thank you very much:) I found first NordPool function that deliver the similar thing. i had to add Integration with Nord Pool first. But the tibber.get_prices was simpler, just that it was “hidden” in normal view. Is there any list of all these good-to-know variable names? Now I’m looking widely for the Consumption (kWh) each hour from date selection. Is that possible? it dont seem to be a structure under tibber, but Im might be wrong.
action: nordpool.get_prices_for_date
metadata: {}
config_entry: 01M41NTP94A0NVHG7HGC9GW62S
date: ‘2026-10-04’
areas:
- SE3
currency: SEK
response_variable: NordPrice1
