Where did all my devices and entites go?
Update: I am able to see the missing entites/helpers/devices if I reboot in safe mode?!
Full disclosure, my setup has been in a good spot for a few months and I haven’t really had the need to dig to deep into anything over the past couple weeks. However, today I went to look at a specific entity and was surprised to see that none of my Devices/Entities/Helpers are listed in the Devices & Services section of the HA settings menu?! I have checked both desktop and mobile and can confirm no filters are turned on. I’ve attempted to search but nothing populates in the directory?! I even tried to create an entity card on the dashboard and can’t see any when searching from there?? I can confirm they are alive and working if I select any of the ones I have on my dashboard they pull right up. I did just update to the 2026.2.0 release, but to see if that might fix it, but I originally noticed it on 2026.1.3.
Any suggestions?!
Check all your logs for errors in integrations. Safe mode boot basically doesn’t load custom anything, so it is a good chance something there is a problem.
Also… 2024.5+: Tracking down instability issues caused by integrations
@Sir_Goodenough thanks for the suggestion. I was able to see my Backups once I was in Safe mode, allowing me to restore one from last week. Fortunately once I did this, everything fell back to the way it should be. So weird that any search I did would just simple yield 0 results in the way of devices/entities/helpers. Nevertheless it seems to be working once again. Thanks!
If it’s an integration problem, it will likely be back.
Look at your logs…
Hi, good that you got it solved!
Also: please take the time to mark the post that holds the answer.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
